Wierd clutch noise
  • #16
    Oh I'm okay, I was just joking.
    • #17
      clutch starplate bearing
      Originally posted by CatatonicBug View Post
      +1. Good idea! Otherwise, when was the last time you changed the oil? Have you switched to your winter viscocity yet? 20W50 is too thick for 45° mornings. It may also have water in it from condensation that doesn't get evaporated on short runs.
      Thanks for all the great insights. Last month I installed a new Barnett clutch and springs and Valvoline 20-50 dino motorcycle oil and filter. I will pull the case and check the bearing on the star plate. If it is bad, is it a special order bearing or something I can buy locally? I hope it is not the clutch shaft bearing. I have no place to pull an engine.
      • #18
        Oh, boy...reminds me of an old friend.....
        Who left his fill plug home....
        • #19
          Originally posted by BA80 View Post
          Take it easy Dogg, we're just messin' with each other.
          If Tod would put his drain/fill plugs back in and tight he wouldn't leak so much oil.
          Wait a minute....Tod misplaces his drain plug too?!
          • #20
            Mine was from my middle drive. It got all over everything by the time I noticed. I had an extra with me and John had some oil, so no harm... except the oil that is baked on to my exhaust that nothing seems to take it off. Tried brake/carb cleaner, Simichrome... thought about a rag with some brake fluid on it next. If that doesn't work, it's the oven cleaner.
            kflyboy, if you have the clutch cover off, you can just grab your whole clutch basket and try to move it side to side and up and down. It may have a little in/out play, but that's normal. No movement should be possible side to side. And as far as I know, if that bearing is out, you'll just need to find another star plate. I took one of those bearings out and tried to find a replacement, but no luck. Doesn't mean it's not possible, but I didn't find one. Luckily, I had a few extra star plates.
            • #21
              Usually you can find a Timken replacement for any bearing. Just find a vendor who has a chart you can use to look it up by dimension. They even have most bearings in full ceramic if you want to drop some serious money.
              • #22
                I have thought about that for degreasing, but some here said that it turns aluminum black.
                • #23
                  It will eat the aluminum, as well as discolor it...
