Looking for "O" rings.
  • brcree
    • Mar 2010
    • 388
    • S.C.
    I have a 81 XS 1100 SH.........looking for the carb. butterfly shaft end O rings. They are under a washer and c clip at the ends of this shaft. Any help would be great!
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
    Those aren't o-rings, they're actually a U-shaped seal. You can still get 'em new....
    http://www.boats.net/parts/detail/ya...997-00-00.html
    • brcree
      • Mar 2010
      • 388
      • S.C.
      Rings....
      Thanks Steve, you are correct. After removing them I see it!. Thanks again. Got them on order.
      At this time:
      1985 Goldwing Innr.
      2007 vtx 1300
      81 sx 1100 s h
      81 sx 400 special
      • 81xsproject
        • 3185
        • Fortuna, CA
        Just FYI on the boats.net seals. Shipping is PAINFULLY slow. Other than that, can't beat the price.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          Hi brcree,
          can you change those seals without dismantling the butterfly & shaft?
          I've always fought shy of that task so mine are presumably the same seals that were installed at the factory.
            • 8054
            www.powersportsplus.com has proven very fast for me.
            • brcree
              • Mar 2010
              • 388
              • S.C.
              Thanks Jet.........@Fred.......they aren't hard to get out, I used a hooked dental pick tool and kept picking at the seals. Just take it easy, by now they are pretty crusty and hard. Take your time and they will come.
              At this time:
              1985 Goldwing Innr.
              2007 vtx 1300
              81 sx 1100 s h
              81 sx 400 special
                ...can you change those seals without dismantling the butterfly & shaft?..
                One side can be replaced, but not both. Part of the linkage is peened onto the shafts, so to get to both seals the butterfly and shaft have to come out...
                • brcree
                  • Mar 2010
                  • 388
                  • S.C.
                  seals
                  Hey Steve......I could get both seals out with no prob. Are the carbs different between the years in this area? I just removed the "C" clips and a washer.
                  At this time:
                  1985 Goldwing Innr.
                  2007 vtx 1300
                  81 sx 1100 s h
                  81 sx 400 special
                    • 8054
                    For your SH, you need seal 256-14997-00-00.
                    Item #38 on the breakdown.
                    Here is the link I got this from:
                    • brcree
                      • Mar 2010
                      • 388
                      • S.C.
                      seals..
                      Thanks Jet.......I guess I should have stated the seals are on the outside of the outer carbs.
                      At this time:
                      1985 Goldwing Innr.
                      2007 vtx 1300
                      81 sx 1100 s h
                      81 sx 400 special
                        There's two seals on each carb; to replace both, the rack has to be broken and the shafts/butterflys have to come out.
                        • brcree
                          • Mar 2010
                          • 388
                          • S.C.
                          seals...
                          My bad Steve......you are correct. I didn't think about the inner ones being bad. Live and learn.
                          At this time:
                          1985 Goldwing Innr.
                          2007 vtx 1300
                          81 sx 1100 s h
                          81 sx 400 special
