Replacement Exhaust
    You'll get a bit more noise and a slight power loss. If backpressure is roughly the same, no tuning should be needed.
    • PapaBear1950
      • Sep 2012
      • 36
      • Wichita, KS.
      So straight pipes are a no no...
      Yamaha 80
      Suzuki TM 400
      Honda CB 400
      Yamaha XS650 chopper
      Honda 1800 VTX S
      Suzuki C-50 Bobber (wifes)
      HD Road King Classic
      Yamaha XS 1100
        If your going to run straight pipes your going to be lean and without the backpressure it will affect the top end.
        Not only that, your ears will be bleeding.
        • jwhughes3
          • 2798
          • Home of the Alamo
          BLUF: Stock pipes and mufflers are best, 4-1 or 4-2 with crossflow second, straight pipes not recommended.
          The center crossflow is what helps the stock pipes perform so well since the crossing of cylinders 1-4 and 2-3 gives countering backpressure. MAC 4-2 systems, for instance, lack the crossflow and are aesthetically pleasing, but would make tuning very difficult in the high range when gasses are moving fast. This is usually worsened when the stock airbox is replaced with pods that increase the flow rate. Pods with stock exhaust can be countered with jetting, with 4-2 you run risk of leaning out to the point of catastrophic damage.
          John
          '81 XS1100H - "Enterprise"
            Only if you want a bike that runs right....
            Straight (AKA drag) pipes have become 'acceptable' because of some of the Harley crowd (mostly the 'loud pipes save lives' bunch) but it's been dyno-proven time and again that you lose a lot of power at most points on the power curve. Plus it's all-but-impossible to tune the bike to run well at all rpms.
            The XS11 is a extremely well-tuned package as delivered, so nearly any changes to the intake or exhaust will degrade the power output at some point. If you do manage to find more power (usually on the top end), you'll suffer a corrosponding loss at lower rpm (where you run the bike 95% of the time).
            If you're talking to Harley guys or come from that background, remember that nearly all HD products are sold with very restrictive intake/exhaust. Almost any change will result in more power over stock (even if the bike runs poorly at some rpms), and a proper intake/exhaust upgrade can increase power up to 20%. You'll never see that much on the XS, and more often than not will lose power....
              • 3950
              Nice price for a MAC system.
              http://www.ebay.com/itm/Exhaust-Yama...e4cc49&vxp=mtr
                • 3950
                I have a mint condition Hooker 3-2 exhaust from my 750, as well as two OEM exhaust systems from my 750. Any reason why I cannot weld the mufflers right onto the OEM headers of the 1100?
                • senrak
                  • Jun 2012
                  • 70
                  • Rhinelander, WI.
                  Originally posted by tinman905
                  Have a look at these . They look like they are off a XJ1100
                  http://www.ebay.ca/itm/280990402540?...84.m1423.l2649
                  Thanks Tinman,
                  I was able to sustain the winning bid on this exhaust system. The only thing remaining is to get them in my garage. If they are as nice as they look in the photos I'll be a very happy man. I don't believe there is anything that looks better than the original pipes. Again, thanks for the heads-up.
                  DW
                  82 XJ
                    • 3950
                    I have a feeling my tax return will be going towards Supertrapp mufflers or an original exhaust system. We'll see . . .
