Pre sync
Did you do the pre sync as it is shown on this site? was the idle screw all the way down when you were done? Did all the throttle plates have the same clearence when you were done ? Did you answer yes to all the questions ? lol, Then that should be fine then i would suspect the throttle cable. HTH ..........MITCH
