fuse box question
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    I put mine on tonight. The connectors he sells with the blocks are nice but farily difficult to get crimped down tight. I had a problem with a couple of them.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    • Gallaecus
      • May 2011
      • 254
      • East Haven Connecticut
      i was just saying that i appreciate what it is, what it was and how it was built.
      Steven
      1981 XS 1100 LH
      1979 XS 1100 SF
        • 8077
        Actually, the blue connectors are for the larger gauge wire. The connectors for the smaller gauge wires are red (pink). Getting the blue ones tight is a little more of a challenge. They work, just be advised they're larger than necessary.
        • Tat2demon
          • Jun 2012
          • 718
          Ah ha. I only got blue ones with mine.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
            Originally posted by DGXSER
            Now, you still need care when installing TCs as well. A few years ago, when I first joined the site, there was a local XSive that could not get his bike to start after installing the new fuse box. I went over and looked at it with him, used my meter to trace out the problem. Voltage followed right along to the fuse box, through the new fuse to. After about fifteen minutes of tracing wires we found that one of his crimp connectors was not tight. Wire pulled right out. Put on a new crimp connector and it started right up.
            And that is why you always give the wire a tug after putting a connector on.
              To be honest Nate, it may not have been THAT loose. But it was loose enough to give intermitent contact at best.
                • 8077
                TC kindly supplies you with the blue ones. If you want the smaller ones, you have to procure them yourself. I bought them at my local Ace Hardware.
                • Mr.Bill
                  • Aug 2009
                  • 118
                  • Clarksburg Maryland
                  AS TC mentions in the coorespondance when I ordered mine, Easy to just double over the thinner wire and crimps nicely in the blue connector.
                  My bike was dead as a doornail, and after replacing the fuse block, I was a happy camper when I turned the key, and the neutral light came one, cranked it over and the oil light went out, and the brake light worked (from the foot brake) as well as the left and right turns front and back
                  And this was from that basket case that some had seen in my initial post here, and all that from just the new fuse block.
                  And yep pulled the plugs, and there be spark also.
                  1979 XS1100SF.
                  "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
