I put mine on tonight. The connectors he sells with the blocks are nice but farily difficult to get crimped down tight. I had a problem with a couple of them.
fuse box question
Nate
78 XS11 "Matilda" 2H7 000364
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim
Originally posted by Tat2demon View PostI put mine on tonight. The connectors he sells with the blocks are nice but farily difficult to get crimped down tight. I had a problem with a couple of them.
Ah ha. I only got blue ones with mine.Nate
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim
Originally posted by DGXSER View PostNow, you still need care when installing TCs as well. A few years ago, when I first joined the site, there was a local XSive that could not get his bike to start after installing the new fuse box. I went over and looked at it with him, used my meter to trace out the problem. Voltage followed right along to the fuse box, through the new fuse to. After about fifteen minutes of tracing wires we found that one of his crimp connectors was not tight. Wire pulled right out. Put on a new crimp connector and it started right up.Nathan
To be honest Nate, it may not have been THAT loose. But it was loose enough to give intermitent contact at best.Life is what happens while your planning everything else!
Originally posted by Tat2demon View PostAh ha. I only got blue ones with mine.Marty (in Mississippi)
AS TC mentions in the coorespondance when I ordered mine, Easy to just double over the thinner wire and crimps nicely in the blue connector.
My bike was dead as a doornail, and after replacing the fuse block, I was a happy camper when I turned the key, and the neutral light came one, cranked it over and the oil light went out, and the brake light worked (from the foot brake) as well as the left and right turns front and back
And this was from that basket case that some had seen in my initial post here, and all that from just the new fuse block.
And yep pulled the plugs, and there be spark also.1979 XS1100SF.
"You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
