Fork oil volume
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Fork oil volume
    Just replaced fork seals, using progressive springs and 15wt synthetic oil.
    How much to put in? I remember somewhere between 7 and 10oz. No fairing for now but do ride double often with tank, tail and saddle bags.
    BAMN!
    '81 XS1100H "Brutus"
    • 8930
    Taken from the Clymers manual, the 81H model calls for 241cc (8.15 oz) per leg.
      • 9981
      Hmmmmm...........my Clymers says 7.17oz or 212cc for the standard forks and 7.61oz or 225cc for the special.
      • Nubian
        • Apr 2011
        • 467
        • The Big East
        What about if upgraded to progressive springs would that not change the volume? FSM calls for 8.15oz each leg. I misplaced the install sheet that came with the springs which specified how oil to use.
        BAMN!
          • 9981
          The springs shouldn't really make a difference there because they won't change volume.
          • Nubian
            • Apr 2011
            • 467
            • The Big East
            Alrighty then!
            Thanks everyone.
            BAMN!
              Progressive will specify a fork oil volume with their springs as changing weight/amount will change how the fork reacts. If may or may agree with factory specs, I'd contact Progressive to see if it's different. Particularly if converting from the air-assisted factory springs to Progressive units...
                bikerphil had it correct. The SH is 7.10oz..........right out of the original owners manual. BTW, the H(Venturer) had progressive springs from the factory, unless someone swapped them out.
                  • 9981
                  My manual doesn't seem to cover the Venturer. Better listen to those that own one and have an original manual.
                    • 8930
                    Gotta look in the back of the book for the 80-81 models.
                      • 9981
                      Never actually seen that supplement Phil. Thanks for the heads up.
                      Seems to only cover the 80 + 81 standards and 81 specials though. Nothing for the SG.
                      • xs11lover
                        • 1433
                        • Montoursville Pa
                        Volume?
                        I like it loud.
                        My factory manual doesn't cover 81. Just 78 to 80.
                        79 XS11 Special (Lazarus)
                        79 DT 100
                        • Nubian
                          • Apr 2011
                          • 467
                          • The Big East
                          That's what I specifically remember from my last install but could not find the progressive paperwork that came with the springs. Was trying to avoid a mess with draining/refilling to get correct amount. Oh well, I already put in 8oz in each and plan on buying those syringes, and will not be using air. Will contact Progressive and how far off I am.
                          BAMN!
                            I haven't used Progressive springs in a XS, but I have installed them in other forks. They don't generally give an amount, but rather a 'level', i.e. a distance from the top of the fork tube to the oil, that's with the spring out. They're looking for a specific amount of air left in the fork once it's sealed up. A bit of a PITA to measure, I did one side and kept track of how much I put in and duplicated it for the other side... and wrote down the amount for next time...
                            • Nubian
                              • Apr 2011
                              • 467
                              • The Big East
                              I used a small sqiare to measure level last time it wasn't too bad.
                              BAMN!
