Can I use a front spoked wheel from an XS650 or at least the front hub to lace my own wheel? I know the rear GX750 will convert with the rear.....
spoked wheels
from memory u should be able to use the
whole front wheel.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
Yes, you can use an XS650 wheel. It is a direct swap. It has provisions for brake rotors on both sides. If you use a 1977 and later wheel, even the brake rotors are the same as the XS1100.Marty (in Mississippi)
XS650EComment
Theodore RooseveltComment
Gx750
I have never seen such a thing as this:
XS650EComment
Hi Arden,
like Marty sez, an XS650 front wire wheel plugs right in.
The prettiest is the early 36-spoke deep groove aluminum rim but it's stock disks are dished wrong for the XS11's calipers.
Your XS11 disks bolt onto that wheel OK as will post '77 XS650 disks.
Later "megaspoke" XS650 wire wheels work disks and all but they have steel rims and the "megaspoke" look is an acquired taste.
A wire wheel rear takes serious machinist & welders skills and equipment to cut an XS11 rear wheel down to a hub and weld on spoke rings to lace your new rim onto. Or incredible good fortune to find those incredibly rare GX750 wheels.
Way back when I still reckoned that the look of wire wheels exceeded the inconvenience of having to run tubes in them and of keeping them clean,
I'd have wired the front and left the rear as a cast wheel.
Looked OK on the Münch Mammoth, eh?Fred Hill, S'toon
"The Flying Pumpkin"Comment
