spoked wheels
  • arden666
    • 5
    • Reno, Nv.
    spoked wheels
    Can I use a front spoked wheel from an XS650 or at least the front hub to lace my own wheel? I know the rear GX750 will convert with the rear.....
  • petejw
    • 2269
    • sydney australia
    from memory u should be able to use the
    whole front wheel.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      Yes, you can use an XS650 wheel. It is a direct swap. It has provisions for brake rotors on both sides. If you use a 1977 and later wheel, even the brake rotors are the same as the XS1100.
        HAHAHAHAHAHAHAHAHAHA!!!! Good luck finding the gx750 rear wheel!
          Gx750
          I have never seen such a thing as this:
            That is because it was the early first year Japan only release of the xs750. Very few were made.
              Hi Arden,
              like Marty sez, an XS650 front wire wheel plugs right in.
              The prettiest is the early 36-spoke deep groove aluminum rim but it's stock disks are dished wrong for the XS11's calipers.
              Your XS11 disks bolt onto that wheel OK as will post '77 XS650 disks.
              Later "megaspoke" XS650 wire wheels work disks and all but they have steel rims and the "megaspoke" look is an acquired taste.
              A wire wheel rear takes serious machinist & welders skills and equipment to cut an XS11 rear wheel down to a hub and weld on spoke rings to lace your new rim onto. Or incredible good fortune to find those incredibly rare GX750 wheels.
              Way back when I still reckoned that the look of wire wheels exceeded the inconvenience of having to run tubes in them and of keeping them clean,
              I'd have wired the front and left the rear as a cast wheel.
              Looked OK on the Münch Mammoth, eh?
