Vibration
  • mack
    • 2411
    • Ontario, Canada
    Dampeners
    I just started to reconditioned my failed motor mount Dampeners today. If it all comes out as I think it will, I should be able to refurbish four at at time for $13.00 canadian. Let me complete this and I'll run it by Steve with photo's he can touch up and maybe we'll have a technical tip everyone needs sooner or later.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      Motor mount questions:
      Okay, now I've got the Poly bushings on the way, I was looking at the bike and where the mounts are and oh boy, the rear mounts look like they're gonna be a pain in the butt to swap out.
      Any ideas?
      I was kinda thinking about supporting the motor with a jack while bike was on centerstand and then removing all the mounts. Then with all the mounts out, I can 'jack' up (or lower) the motor a few inches to get the rear bushings out and swapped, then lower (or raise) it back down and then do the fronts.
      Any and all ideas/thoughts welcome. This will be my first time messing with motor mounts. I've played a little with the rear one, just once to replace foot pegs.
      I can document my poly swap and Steve can put the 2 together or have 2 separate tips to post up.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        I'll mention some things the tech guy that I talked to about these bushings said...
        If you find that you need to mod the bushings for fit, he recommended freezing them before trying anything, the colder the better. At room temp, the plastic will tend to tear rather than cut. If you decide to enlarge the center hole, try to find a drill bit (in the proper size) for plastic (they are different). Let us know how this goes....
        • GLoweVA
          • Jun 2011
          • 1957
          Thanks Steve, I think that might be a big help if I find that things aren't fitting together well enough.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
          • mack
            • 2411
            • Ontario, Canada
            rear dampeners
            You probably won't have to change the lower front or rear dampeners. They are a bit different in design and not subject to the same environmental stress's as the front uppers. Have a look and if you still have rubber between the metal, your good. However if they do need changing you might get away with removing the front upper dampeners and stanchions, loosening the front lowers, disconnecting the drive shaft then removing the rear through bolt. You might be able to rock the motor forward enough on the front mounts to be able to gain clearance to remove the rear dampeners.May have to remove the battery box too. Not a quick easy job regardless considering it's riding season. Be a good winter project though.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • GLoweVA
              • Jun 2011
              • 1957
              Mack, thanks for the tip. From a quick inspection, the rears look okay. I might just do the front uppers and see if that helps/cures my vibration. Then I can plan on the other 4 for this winter when it's cooler out an I've got my SG up and running, that way I still have a bike to ride while the G is down.
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
