Vibration
  • mack
    • 2411
    • Ontario, Canada
    Vibration
    Had a good ride yesterday. My brother and I had both bikes out for a 230 mile tour. A couple spots we had a chance to open them up a bit. We both experienced vibration starting around 5K RPM. Not white knuckle time or anything but definately noticeable.
    I don't think it's motor mount related and both engines are smooth a silk other wise.
    Plugs are perfect. No stumble at all throughout the tach range on either. Cam witness markers are dead on.
    Both sets of ignition coils gave all the proper readings.
    Both bikes have new plugs and caps.
    I have 404's on the SF and Battle axes' on the LH.
    New front and rear wheel bearings on both.
    However I've had to retorque the exhaust headers a couple times after a ride on both bikes. Was wondering if anyone has had a similar issue and was able to solve it by putting in a second set of header /exhaust washers.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • James England
    • 3039
    • North of England
    They just do that. If it's not white knuckle bad, then it's not too bad. I use spring washers on the header studs.
    Is your exhaust system isolated correctly from the frame by use of rubber bushes? Or is any part of the exhaust system attached directly to the frame/mounts without any isolation?
    • mack
      • 2411
      • Ontario, Canada
      Mounting
      Hi James, Happy Fathers day by the way.
      The only contact with the frame is at the foot rests and yes the bushings were installed. The only other contact point is at the header/ exhaust flange. Was thinking the nuts bottom out before the flange is fully seated. Thought another gasket could cure it.
      What ever it is, both bikes have it, so it must be something I've done; or, didn't do.
      I have some family stuff today as I'm sure we all do, but I'll try to fire them up today and just hold the rpm at 5-6 k in neutral (outside) and see if it is still there. May even do a hot compression test.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Maybe an exhaust leak under the heat shield? Specials are known for that, but it would probably cause popping on decel. The thing to determine is whether the vibration is an rpm thing or a speed thing. If it is a speed thing, there might be a tire balance issue.
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          I would caution against reving them up in neutral fior any length of time. IIRC the manual says not to rev over 3k in neutral... I think what you both are experiencing is just some vibration from the exhaust. I think all of these bikes have a buzz in the foot pegs and even in the bars between 4-5k rpm, its just their nature... I wouldnt get to concerned unless its more than just a buzz in that range... just my 0.02$
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • James England
            • 3039
            • North of England
            Yes, definitely a buzz is usual in the 4-5 thousand band. My wonderful XS1100 caused my middle finger on my right hand to go white! Weird! And, everything about that bike was perfectly maintained and balanced etc.
            Like I say, if it's not white knuckle stuff, then I really wouldn't bother.
            Do your headers have the metal collars that tighten the flange onto the head? Your nuts shouldn't really bottom out when tightening
              Might wanna pull back the front portion of rubber boot and check U-joint for hoizontal and end play...........JAT........BTW, if all is correct on these bikes there is no buzzy vibration at any particular rpm.
              • mack
                • 2411
                • Ontario, Canada
                Found it (hopefully)
                I think I found my problem. The upper front right motor mount had a deteriorated bushing so it was metal on metal. Looked ok from a distance but once I got a good look with lighted scope it obvious. I have a spare set I got from Andreas last year so I'm going to pop them in tomorrow and see for sure. I'll get back to all with the result. I was looking through the repair forum and found one on bushings, they're not rubber. Has anyone tried this, if so how did it work for you?
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • mack
                  • 2411
                  • Ontario, Canada
                  Motor mount
                  Just to follow up on the vibration. It was the dampener on the front upper that was the problem. Switched the uppers out yesterday and all is well now.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    This Thread got me thinking about why my right hand goes numb after about 30 mins of riding.
                    I'm gonna check out my mounts and see what's going on.
                    I just looked at that modification tech tip on the aftermarket poly bushings and for $2.50 each, for a total of 6, that's only $15 and only $5 for shipping.
                    I think I'll order some and see about replacing them anyway.
                    With almost 100K on my bike and as many oil leaks I've had over the years, I'm sure my 30year old rubber bushings are probably shot anyway.
                    I'll try to snap some pics of the swap so Steve can add it to the tech tip.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                    • rombat
                      • Sep 2010
                      • 30
                      • Saskatoon, Saskatchewan
                      One other possibility for vibration is a carb sync setting. My XJ was running fine but my fingers would get numb after 20-30 mins. After a regular maintenance carb sync, it was off just a bit between 1-2 and 3-4, the vibration was gone.
                      1100 Maxim (daily rider)
                        George, do you have a link to the bushing source? Something I may be interested in doing.
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          Phil, Here it is: http://www.suspension.com/4-bar.htm
                          I just got off the phone with them, seems really nice and with the $5 USPS if it fits it ships box, can't beat it.
                          I ordered 6 #2008 that Steve posted about in the tech thread.
                          Should be here hopefully by Sat.
                          BTW, they only come in black, which is perfectly fine with me.
                          The Green Monster
                          Got him in '04.
                          Scarlet
                          Got her in '11
                          Hugo
                          Cold weather ride
                            Thanks George.
                            • YamaRule
                              • Apr 2010
                              • 29
                              • Nova Scotia
                              Wheel weights!!!
                              I melted some wheel weights and poured the liquid lead into my handlebars. solid lead core from one end to the other and worked great. I poured a little to create a cap on the bottom end. Once it solidified I put the handle bars in a bucket of cold water to prevent discoloration while pouring the rest!
