Hummm,
From what I can gather from all the postings, is that it happens on the swirly wheels, and happens when the o-rings get worn or deteriorated.
The straight spoke wheels use the same 0-rings, so why don't they exhibit the same problem?
It sounds like it is either the metal to metal contact between the hub and wheel slipping (stiction, )when the wheel compresses the rubber bushings as the wheel rotates, or the o-ring rubber slipping and causing the noise, although that doesn't sound likely.
I'm getting ready for a trip to the left coast next week, (I'm riding the XS, not the XJ), so I don't have time to investigate until I get back, but if you delve in, be sure to post results. And the sizes given for the 0-rings don't look right for metric sized rings, so there is that problem. They may be special sized one for OEM use.
Anyway, I wouldn't park it, but I wouldn't plan any long trips, and if it gets worse, quit and fix. CZ
