This is mostly for you guys on the other side of the pond or anyone who may know. Has anyone ever tried carbs from a FJR 1300 on a XS1100.
FJR1300 carbs
FJR1300 carbs
USMC 2005 - Present
79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
78 XS1100E - Rebuilt And Sold
I SHOULD OF KEPT IT!!!Tags: None -
Ok I'll bite ...........Do FJR1300's have carbs??
Or are you asking if you can fit FJR1300 EFI throttle bodies to an XS1100?
Dunno
.Tom
1982 XJ1100, waiting resto to original -
All injected as far as I know... XJR's, however, were carbed until about 2007.Last edited by b.walker5; 06-10-2012, 01:11 AM.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
Tom
1982 XJ1100, waiting resto to originalComment
They also went from a 4-2 exhaust to a 4-1 at the same time. Looking at the carb son my XJR1300, I'd say the would physically fit easily. The choke cable system would be needed from the XJR, although a pull toggle could be fitted at the side of the carb.
There's no carb stub for connecting the XS1100's vacuum advance though...XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Sorry I meant XJR1300 and they are BS37's I know they have an electronic choke and that would need to be changed but I was wondering if anyone has already tried the carbs and of so how where they. I got a set with the 78 XS1100E project I bought. They came in a box with all the other parts that weren't installed. I might try them or just sell them if I can find someone who will buy them especially since the bike was a European only model.USMC 2005 - Present
I SHOULD OF KEPT IT!!!Comment
They dont have an electronic choke, I think. You are looking at the black things with 2 wires attached to each carb? If so, they are small heaters to heat the fuel in very low temperatures. The choke is manually operated by cable from the left handlebar.
I looked at my XJR carbs and wondered the same thing re fitting them to an XS1100. I bet they'd work...XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
The heater makes more sense for that connector. If I don't end up using them I am going to at least use the idle screw off of them because it would be way easier to adjust. I will let everyone know tho. Or if your looking for a compete set of XJR 1300L carbs send me a pm. Even tho I doubt anyone will be looking for them.USMC 2005 - Present
I'd be interested in buying them! The only slight problem would be the feasibility of shipping them to the UK..The heater makes more sense for that connector. If I don't end up using them I am going to at least use the idle screw off of them because it would be way easier to adjust. I will let everyone know tho. Or if your looking for a compete set of XJR 1300L carbs send me a pm. Even tho I doubt anyone will be looking for them.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
If that electrical thingy is mounted on the butterfly shaft it must be a TPS (throttle position sensor) normally connected to the xjr's ignition.
No need to use that, although you could use it with an aftermarket ignition..
The BS37 is most probably overkill on a stock bike , so the 36 is more recommendable. I know several people in germany that use these, biggest problem will be drilling carb nr2 at the very same location as the stock carbs to fit the vacuum spigot. Even that is not necessary but without the vacuum controlling the ignition you will lose some of the XS's famous torque..XS1100 3X0 '82 restomod, 2H9 '78 chain drive racer, 3H3 '79 customized.
MV Agusta Brutale 910R '06.
Yamaha MT-09 Tracer '15 grey.
Kawasaki Z1300 DFI '84 modified, red.Comment
Depends, Mathh, on whether there's one black thingy on each carb, or one black thingy for the whole bank. The TPS is is only on one carb, on the outside, whereas the heaters are on each carb. The heaters only operate when the temperature is below 13 degrees centipede, to prevent the carbs from icing up, but most of the time they're not needed.1980 SG. (Sold - waiting on replacement)
USMC 2005 - Present
There is just one black connector receptacle on the outboard side.Depends, Mathh, on whether there's one black thingy on each carb, or one black thingy for the whole bank. The TPS is is only on one carb, on the outside, whereas the heaters are on each carb. The heaters only operate when the temperature is below 13 degrees centipede, to prevent the carbs from icing up, but most of the time they're not needed.USMC 2005 - Present
