FJR1300 carbs
  • mmaddix
    • Jul 2011
    • 232
    • Beaufort, SC
    FJR1300 carbs
    This is mostly for you guys on the other side of the pond or anyone who may know. Has anyone ever tried carbs from a FJR 1300 on a XS1100.
    USMC 2005 - Present
    79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
    78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
  • TomB
    • 967
    • Cumbria, UK
    Ok I'll bite ...........Do FJR1300's have carbs??
    Or are you asking if you can fit FJR1300 EFI throttle bodies to an XS1100?
    Dunno
    Tom
    • b.walker5
      • Feb 2009
      • 1745
      • Invercargill, New Zealand
      All injected as far as I know... XJR's, however, were carbed until about 2007.
      • TomB
        • 967
        • Cumbria, UK
        I have used XJR12 carbs on my XS11 so I'd assume the XJR1300 carbs would fit, I think they're BS37's instead of the XJR12's BS36's
        Thats IF you're talking about XJR not FJR carbs
        Tom
        • James England
          • 3039
          • North of England
          They also went from a 4-2 exhaust to a 4-1 at the same time. Looking at the carb son my XJR1300, I'd say the would physically fit easily. The choke cable system would be needed from the XJR, although a pull toggle could be fitted at the side of the carb.
          There's no carb stub for connecting the XS1100's vacuum advance though...
          • mmaddix
            • Jul 2011
            • 232
            • Beaufort, SC
            Sorry I meant XJR1300 and they are BS37's I know they have an electronic choke and that would need to be changed but I was wondering if anyone has already tried the carbs and of so how where they. I got a set with the 78 XS1100E project I bought. They came in a box with all the other parts that weren't installed. I might try them or just sell them if I can find someone who will buy them especially since the bike was a European only model.
            USMC 2005 - Present
            • James England
              • 3039
              • North of England
              They dont have an electronic choke, I think. You are looking at the black things with 2 wires attached to each carb? If so, they are small heaters to heat the fuel in very low temperatures. The choke is manually operated by cable from the left handlebar.
              I looked at my XJR carbs and wondered the same thing re fitting them to an XS1100. I bet they'd work...
              • mmaddix
                • Jul 2011
                • 232
                • Beaufort, SC
                The heater makes more sense for that connector. If I don't end up using them I am going to at least use the idle screw off of them because it would be way easier to adjust. I will let everyone know tho. Or if your looking for a compete set of XJR 1300L carbs send me a pm. Even tho I doubt anyone will be looking for them.
                USMC 2005 - Present
                • James England
                  • 3039
                  • North of England
                  I'd be interested in buying them! The only slight problem would be the feasibility of shipping them to the UK..
                  • Mathh
                    • Nov 2006
                    • 699
                    • Beek, Netherlands
                    If that electrical thingy is mounted on the butterfly shaft it must be a TPS (throttle position sensor) normally connected to the xjr's ignition.
                    No need to use that, although you could use it with an aftermarket ignition..
                    The BS37 is most probably overkill on a stock bike , so the 36 is more recommendable. I know several people in germany that use these, biggest problem will be drilling carb nr2 at the very same location as the stock carbs to fit the vacuum spigot. Even that is not necessary but without the vacuum controlling the ignition you will lose some of the XS's famous torque..
                    MV Agusta Brutale 910R '06.
                    Yamaha MT-09 Tracer '15 grey.
                    • b.walker5
                      • Feb 2009
                      • 1745
                      Depends, Mathh, on whether there's one black thingy on each carb, or one black thingy for the whole bank. The TPS is is only on one carb, on the outside, whereas the heaters are on each carb. The heaters only operate when the temperature is below 13 degrees centipede, to prevent the carbs from icing up, but most of the time they're not needed.
                      • mmaddix
                        • Jul 2011
                        • 232
                        • Beaufort, SC
                        Well send me a pm with the address and I can look around and see some prices.
                        USMC 2005 - Present
                        • mmaddix
                          • Jul 2011
                          • 232
                          • Beaufort, SC
                          There is just one black connector receptacle on the outboard side.
                          USMC 2005 - Present
