Questions 1196cc big bore kit
First who has done the kit and hows things going?
Second I know several of you can answer but I need to know for sure if the clymer manual is correct on the piston side clearance being 0.0016-0.0018 Just me thinking but with this being aircooled I'd expect more like 0.004 as 0.0016 is very tight. I have a machine shop ready to do a cylinder set I got that was a good candidate as it had bad wear, looks like rings broke.
My measurements from the 1196 overbore pstons are 2.9331in which translate to 74.5 mm. Add to it 0.0016 and 2.9347 is what I come up with as bore for cylinders. Need you guys to verify this as I do not want to seize a set of pistons. I will still have to clay the head make sure of valve clearance.
I do plan on folowing a break in procedure when its all done.
