so im doing a valve job, and had to remove the cct...i was looking online to figure out how to adjust it upon re-installation, and realized that mine is not functioning properly...first there is no locing screw, just a brass locking bolt, it looks more like a hollow plumbing bolt than an oem one, also there isnt an oring or washer...then once i pulled it off the bike, there is no slack in the spring or the rod, in fact it wont budge at all...i cant take the spring or rod off, and i cant compress it in....
The auto CCT unit is now on and installation was easy, save for a little filing of the mounting holes. It cannot back out, and needs no adjustment.
