cct problems...
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    cct problems...
    so im doing a valve job, and had to remove the cct...i was looking online to figure out how to adjust it upon re-installation, and realized that mine is not functioning properly...first there is no locing screw, just a brass locking bolt, it looks more like a hollow plumbing bolt than an oem one, also there isnt an oring or washer...then once i pulled it off the bike, there is no slack in the spring or the rod, in fact it wont budge at all...i cant take the spring or rod off, and i cant compress it in....
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Sounds like your best option is to replace it with an auto ratcheting one. Unless you you planned to have the bike back together for tomorrows commute, I wouldnt waste one second on that thing. It sounds like its been PO'ed.
    Ps. You're supposed to unlock the set screw to be able to move the plunger. If you have already released it, it might be hung up on a burr on the plunger shaft...
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      Yeah, you would need to loosen that brass bolt there for the plunger to move. But I do agree, go with one of the auto cct's and then forget about it.
      • EricHa
        • Mar 2009
        • 201
        • IL
        +2 on the auto CCT. I recently had the stock unit back out and cause a loose chain, even after torquing the set screw to the factory torque spec. The auto CCT unit is now on and installation was easy, save for a little filing of the mounting holes. It cannot back out, and needs no adjustment.
        1979 Yamaha XS1100SF (gone)
        Airbox w/K&N element
        Jardine 4 into 1
        145 mains, 45 pilots
        1996 Ducati 900SS CR
        1977 Kawasaki KZ900-A5
        1975 Honda CB550K
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          You get the right one and there is no filing involved...
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            Put one in my G
            Yeah, +1 on the ACCT.
            I picked up a Raptor 660 ACCT off ebay for 1.99 + 6.00 S&H.
            Put it on Sunday and it was a direct fit, no filing needed.
            Even the stock (new) gasket was a match.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • EricHa
              • Mar 2009
              • 201
              • IL
              I used the Raptor 660 unit as well, but did need to reem the holes slightly. The mounting bolts would begin to thread, but not go in finger tight. I could have wrenched them in with a hex key, but a little filing on this one was the way to go.
              Jardine 4 into 1
              1975 Honda CB550K
              • GLoweVA
                • Jun 2011
                • 1957
                Eric, Maybe there's a sllight difference between the SF and G so that mine didn't have any issues with the bolts.
                I was a little worried that the bolts might be too long, but it snugged down real easy and the bolts didn't bottom out.
                After I got it in there, I went ahead and rotated the crank by hand to see what was going to happen and as it spun, I could hear the clicks and the slack went away. WHOO HOO!
                Either way, the ACCT IS DEFINITELY THE WAY TO GO!
                The Green Monster
                Got him in '04.
                Scarlet
                Got her in '11
                Hugo
                Cold weather ride
                • EricHa
                  • Mar 2009
                  • 201
                  • IL
                  George, I wonder if it's a variance when they drill the cct mounting holes in the casting. Either way, the ease of installation and improved control of the cam chain is reason enough to upgrade.
                  Jardine 4 into 1
                  1975 Honda CB550K
                  • jimbyjimb
                    • Feb 2010
                    • 263
                    • Seattle
                    Add another in favor of the ACCT.
                    1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
                    2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
                    1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
                    1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.
                    • airborneXS
                      • Feb 2012
                      • 338
                      • Houston, TX.
                      My bad guys I couldn't find the thread, sorry for starting a second one...I've been having problems pulling xs11.com up on my home computer. I thought the site was down all week, it came up on my home computer just long enough for me to post this first ddr posts then went off again. After a week I got curious, turned my wireless off and pow xs turned on on my phone...this sucks but at least im back...I didn't realize how much I relied on u guys to keep this old girl alive...lol
                      Wolf
                      Moto Militia MC
                      • WSL91
                        • Feb 2012
                        • 427
                        • Quad Cities, IL
                        There are a lot of 660 Raptor CCT are they supposed to have some kind of shoe or wiper on the end of the plunger? Both of my factory ones are leaking, 1 real bad and I want to replace them
                        Thanks
                        1970? Honda Z50... gone
                        1974 Honda CB200... gone
                        2008 Honda VTX 1800F
                        http://www.johnsoldiron.com
