valves...i feel stupid...
    Originally posted by airborneXS
    how often does everybody on here actually check their valve shims....
    Some of yours are at minimum spec, so you'll want to check again before too long; say about 3-5K miles. It also depends on which 'spec' you run; the 'early' ('78-79) intake clearance is .006-.008", the late is .004-.006". All use .008-.010" for the exhaust. If set to the early spec and at the high end of the range, checking every 10-15K will probably be ok. The valve clearances don't close up that quickly generally, but if your top end gets quiet, it's time to look...
    The valves shed heat by the amount of time they're on the seat, so tighter clearances reduces that and can increase wear. But these motors are pretty bulletproof... the XJ I'm rebuilding was down to .004" or less on all the valves and showed poor compression and ran poorly. Reshimmed the valves and compression came right back up... I'm not recommending you let them go that long, but that shows what they can tolerate.
    • mack
      • 2411
      • Ontario, Canada
      Noise
      Just redid all my shims on my SF yesterday, put them all at the upper limit. Man is it ever noisy now. On the other side of the coin though, it is running likeit did thirty years ago. Very smooth and lots of get up.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • airborneXS
        • Feb 2012
        • 338
        • Houston, TX.
        after struggling with the damn motion pro valve adjustment tool, i went ahead and just puuled the cams...these are the measurements i came up with...
        Valve: feeler clearance: shim #:
        1E: .20mm 280
        1I: .13mm 265
        2E: .20mm 285
        2I: .10mm 270
        3E: .20mm 285
        3I: .15mm 270
        4E: .20mm 285
        4I: .13mm 280
        ive tried reading the valve chart but im just not seeing it.....
        79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
        09 YZF-R1 " Toothless"
        04 Buell XB12R "Butterfly"
        "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
        Wolf
        Moto Militia MC
          • 8767
          All your exhaust valves are in spec but at the tight end of the scale. They are all at .008" and the scale is .008"-.010", by dropping all your exhaust shims one size smaller (.002"), that would put you on the loose (safe) side of the scale.
          1I I would go 1 size smaller, that would put you at .007"
          2I I would go 2 size smaller, that would put you at .008"
          3I I would go 1 size smaller, that would put you at .008"
          4I I would go 1 size smaller, that would put you at .007"
          I have calculated this using the specs for the 78-79 motors which is:
          IN: .006"-.008"
          EX: .008"-.010"
          Me neither, lol
          • airborneXS
            • Feb 2012
            • 338
            • Houston, TX.
            #35
            thanks, i found a better chart that i was able to get what shims i needed right after i posted that, just needed to look harder...my bad...thanks though....
            Wolf
            Moto Militia MC
              • 8767
              No problem, I needed the practice.
