valves...i feel stupid...
    Originally posted by BA80
    ???? A gallon of Castrol GTX 20w50 is about $14 at Wally World too.
    I fail to see how paying a couple extra bucks for the recommended type is unnecessary.
    Having a bad morning Tod?
    I pay anywhere from 12-15 bucks at Wally World for 5 quarts... though occasionally, I've had to pay 18 in a pinch... but I can find the regular Castrol at dang near any hole in the wall country store or place that sells oil. Take that times 4, and soon to be 5, bikes on the road with wet clutches, and you'll see that it's not just a couple bucks. But... my question to you.. is if something even just a couple bucks cheaper works just as well, why would YOU spend the extra money? What about cereal for your kids? Do you get the store brand stuff that's just as good, or do you buy the namebrand stuff? It's just a coupe bucks difference, right?
    As probably hundreds or more can attest on here alone, with hundreds of thousands of miles travelled, the "Motorcycle specific" oils are unnecessary, more expensive, and harder to find if you need a quart on the road. I don't like to carry extra oil with me since I've had partial quarts leak in my bags before. I would also highly doubt that they made that Castrol you run specifically for 30+ year old friction plates, just a general wet clutch use in which they're talking about modern friction discs. So no, it's not going to be the single "Recommended type" for our bikes. As long as it doesn't have the friction modifiers and has some zinc in it, it's the recommended type. If you like the more expensive motorcycle specific oils, that's your choice. If you think the extra money is worth it, that's also your choice, but I have pulled a few of these motors and clutches apart and seen that the cheaper, regular, non-motorcycle specific oils work just fine and have never had a clutch slippage since changing to the better springs.
    Thus, I stand by the statement of unnecessary, more expensive products. Not having a bad morning, or afternoon, just tired of every.....single.....time.... hearing you trying to sell everyone on this unnecessary oil. It's like you work for them or own stock in the company? Just asking to ease up a bit on the sales pitch is all.
    Anyway, sorry about hijacking the thread. Back to the regularly scheduled topic.
    Before you buy a set of feeler gauges to do the valve check, look at the specs of how thin the gaps you need to measure are. Your regular Chinese made off-the-wall $3 feeler gauges from Walmart probably aren't going to work. I had to finally look at a couple auto parts stores to find a set that would measure as thin as the intake needed.
      • 9980
      I think I'm gonna put it on my avitar and in my signature now.....
        You need to turn "sales pitch" unto a link to the oil companies web site though!
        • airborneXS
          • Feb 2012
          • 338
          • Houston, TX.
          ok so my valve clearances are as follows...
          1E: .008 / .20mm
          1I: .005 / .15mm
          2E: .008 / .20mm
          2I: .004 / .10mm
          3E: .008 / .20mm
          3I: .006 / .13mm
          4E: .008 / .20mm
          4I: .005 / .15mm
          79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
          09 YZF-R1 " Toothless"
          04 Buell XB12R "Butterfly"
          "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
          Wolf
          Moto Militia MC
            Ok, with those numbers you're not desperately in need of a valve adjustment. All of them are tight, but not horribly so.
            Your call as to whether or not you want to do an adjustment now....
            • XJkid
              • Jun 2003
              • 280
              • Elk Grove, Ca.
              Grinding the shims on the outer diameter is not a good thing; some of them are quite a tight fit, but I haven't run into one yet (of the right size) that wouldn't drop in with a bit of persausion...
              If the shim can move in the bucket, it could damage the bucket and cause the bucket to stick in it's bore. If it does that, that holds a valve open and you probably just dropped a valve and trashed a motor...
              Fired it up last night and heard a new clicking sound. Pulled the valve cover off and found the washer I couldn't find when I did the job. Also, on one of the valves that I put a grind-to-fit shim in, the bucket will not spin in the bore I took out all 3 that I ground to fit and am replacing with the right thing. I only put on 5 miles with the bad ones in.I hope I did not do any irreversible damage.
              • airborneXS
                • Feb 2012
                • 338
                • Houston, TX.
                So how are my numbers? Do I need new shims? Where do I get shims from
                Wolf
                Moto Militia MC
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  I think you should be more worried about what that washer might have done before the shims... Hope everything works out for you... I recall reading about someone having trouble getting a bucket out of the head and he ended up replacing the head as the bucket and head were messed up and would require machine work. A use head was cheaper. Hope none of your buckets got messed up.
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  '84 Chevy K-10 "Big Blue"
                    • 3180
                    AIRBORNE. I think your question was answered here. This is the problem when someone hijacks a thread as the answers get confused.
                    • petejw
                      • 2269
                      • sydney australia
                      1E: .008 / .20mm
                      1I: .005 / .15mm
                      2E: .008 / .20mm
                      2I: .004 / .10mm
                      3E: .008 / .20mm
                      3I: .006 / .13mm
                      4E: .008 / .20mm
                      4I: .005 / .15mm
                      there fine, if u wanted to be anal u could change
                      2i or 3intake either go up on one or go down 1
                      on the other, but if u didnt want to mess around
                      theyll be sweet for a few more 'miles.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • airborneXS
                        • Feb 2012
                        • 338
                        • Houston, TX.
                        well then...im slapping her back together...the manual states to check every 4000 miles...how often does everybody actually check em?
                        Wolf
                        Moto Militia MC
                          • 9980
                          Check what? ...........
                          • XJkid
                            • Jun 2003
                            • 280
                            • Elk Grove, Ca.
                            We're all good. The washer was not hitting anything of consequence. As for the bucket, it was just the position it was in at the time. I pulled it out and rotated it 180 and - no problem.There is no damage. I took the shims out of an '80 XJ 650 I have and used them in the 1100.That bike is turning into a parts bike for my 1100. Took it for a midnite ride after getting it back together. Runs like a champ.
                            • airborneXS
                              • Feb 2012
                              • 338
                              • Houston, TX.
                              how often does everybody on here actually check their valve shims....
                              Wolf
                              Moto Militia MC
                              • GLoweVA
                                • Jun 2011
                                • 1957
                                • Virginia Beach, VA.
                                airborneXS: how often does everybody on here actually check their valve shims....
                                I check mine about once a year and I ride every day, so I put on about 15K miles between checks. I should probably check them more often.
                                Now that you got me thinking about it, I am planning on replacing my valve cover gasket this next weekend, so maybe I'll check them again.
                                80G (Green paint(PO idea))
                                The Green Monster
                                Got him in '04.
                                bald tire & borrowing parts
                                Scarlet
                                Got her in '11
                                Ready for the twisties!
                                81H (previously CPMaynard's)
                                Hugo
                                Cold weather ride
