And now a new problem soving begins....
    • 9980
    Originally posted by natemoen
    To put it back to stock Nate. GEEZE do I have to explain EVERYTHING to you.
      You know I don't like that chart.
      • petejw
        • 2269
        • sydney australia
        +1 what greg says, start from scratch and go from there.
        personally i think 145 mains with 45 pilots are to big.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
          • 7949
          running out of fuel?
          You said it behaves like it's running out of fuel? Maybe it is. When you stopped and put gasoline in it, did it run fine for 40 miles and then quit? If thats the case, your fuel cap could be at fault. Is the visible portion in good condition? Remove the cap and take it apart. There is a piece of foam in there, and after 30 years, it has rotted. It's plugging the vent. I replaced mine with a tiny piece of Scotch Brite. If the sealing ring is hard and cracked, this may not be the problem as it will vent through those cracks.
            • 9980
            It's not the chart you don't like, you just don't like being wrong.
              Can't argue with all the first hand experience of the people that find those 210 air jets in their '78's.
                • 9980
                Did you ever think that's maybe why you cant rev over 5K?
                  More like 7500, and I don't spend much time there other than In first gear (and I can get up there in first).
                  Also, since the '78's came that way stock, no I don't think that is the problem!
                    • 9980
                    How about I send you a set of 180s and you give it a shot? I'm curious.
                      If you are that curious go for it.
                        • 9980
                        I'll do that. The only thing is, those 45 pilots you have in there may be too big then. Do you still have the original 42.5s?
                          45 was stock. Never had 42.5.
                            - - - An ignition problem can really seem like a fuel problem.
                            Pulled the carbs multiple times and finally discovered an intermittent pickup coil wire problem.
                            Hi Greg,
                            OTOH, I fought with my SG's ignition for an entire effin' week to no avail.
                            A quickie carb clean fixed her right up.
                            • airborneXS
                              • Feb 2012
                              • 338
                              • Houston, TX.
                              @ jet mech, no i went through the vent, thats fine, i can audibly hear it venting sometimes when i stop...when i filled it up it ran the same...im doing the spark plug mod, and #3 and #4 plugs have a light tan color, very good, #2 and #1 have a sooty look with only a quarter of the porcelain tan, it seems maybe those 2 are running a bit rich...i ordered a bunch of jets to play with, i now have 147.5 145 and 142.5 mains, 45 and 42.5 pilots, and 180 and 210 air jets to play with...gotta wait for my gauges to come in so i can make my carb sync tool as my buddy finally took his back....
                              79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
                              09 YZF-R1 " Toothless"
                              04 Buell XB12R "Butterfly"
                              "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
                              Wolf
                              Moto Militia MC
                                • 9980
                                [QUOTE=airborneXS;371629.i ordered a bunch of jets to play with, i now have 147.5 145 and 142.5 mains, 45 and 42.5 pilots, and 180 and 210 air jets to play with....[/QUOTE]
                                OK, one more time................get it running good on the STOCK STUFF before you go changing $hit and causing other problems.
