ok so the carbs are working good. its accelerating great! Thanks for the help with that all of you!
now as before i thought it was because of the carb issue i have a decelleration problem.
on decelleration the motor is sometimes losing all power like it was flooded. i would come to a stop and when i pulled the throttle it would either shut off or just spit and sputter. i can turn it off for a few minutes and itll start again.
before i fixed and installed the carbs i cleaned the plugs and they were new so i kept them. the #3 cylinder was the most fouled.
so after having this problem i nursed it home and start looking at the plugs and noticed the #3 spark plug cap was much hotter than the others. and thats the only plug getting fouled. Covered in black soot.
i started up the bike, let it warm up, got on it and went throught first and second hard to make sure it was acellerating correctly after the carb fix. on decelleration it spit and sputtered and died. nursed home and started checking the plugs and number three is covered in black soot and the plug cap is HOTTTT!!!!
please advise
please advise
