Idle Mixture Screw washer
  • Lbrown311
    • May 2011
    • 311
    • Minneapolis, Minn.
    So during the process of cleaning my carbs I somehow lost 2 of the washers in the idle mixture screw holes. Does anyone know of a replacement without losing an arm and a leg. I do have replacements for the valve seat o-rings and mixture screw o-rings if anyone needs some. I am thinking of buying the smallest washer I can find and grinding it to size. Problem is when they are that small already it could turn out to be a bit difficult to resize them.
    1980 XS1100SG "Black Mamba" 28K
    1979 XS1100F 33k (Current Project)
    1981 XS1100H "Blue Balls" (Crashed and under repair )
    1978 XS1100E "Partsy"
    Work Hard, Play Harder!
    Mic the thing and go to a small electronics store to see of they have anything close. I doubt a hardware store has any that small.
      Also, a hobby shop will most likely have small hardware like that.
      • Lbrown311
        • May 2011
        • 311
        Also have one more question. Does anyone know if the pilot jet passages are plugged with those caps on the 81H or which models even did that? They weren't when I opened the carbs but not much was right either so I am wondering if they are supposed to be. Thanks
          You shouldn't need the rubber pilot jet passage caps on 81 carbs. To verify this, remove the main jet and the emulsion tube and look down the tower. On the side nearest the pilot jet tower, there will either be a crossover hole there or no crossover hole. No hole = no rubber plug needed. Hole present = needs a rubber plug. Early 1980 carbs are the ones that need the rubber plug.
          • Petersg_99
            • Apr 2012
            • 184
            • Phoenix, AZ.
            purchased washers at Ace hardware
            I lost one of the washers this weekend when I was cleaning the carbs out. I found washers with the right outside diameter in the small nut/bolt/washer bin. I had to file out the inside diameter to get it to fit over the needle properly though. cost 0.31 each...
            Guy
            1980 XS1100G - Frankenstein - resurrected from the impound lot
            1991 Suzuki GS500E (not running yet)
            2003 Burgman AN400 - Blue Belle
            2005 Burgman AN400 - Silver Belle
            • Lbrown311
              • May 2011
              • 311
              Bomb digs dude. Do you remember which size you bought or you have the receipt to make it easier for me I left my caliper at my buddies house and couldn't measure it tonight. I ended up finding one of them on my workbench so I just need one more. Inside filing sounds a lot easier tho thats for sure
                Suzuki part #'s for U all.............../o-ring:13295-29900 washer:13291-29900 Suzuki cause NA through Yamaha...........BTDT.
                  • 3193
                  Shows part numbers for them little washers available from Suzuki.
