Oil Seal
    • 9980
    Hmmmmm.......the replacement seal says 32x45x8.
      • 8659
      Yeah, thats for the charging side.
        • 9980
        Ahhhh...OK, I was reading it wrong.
        • Joab
          • Aug 2010
          • 472
          • Ozark, Alabama
          Don't scare me like that!
          Joab
          "If nothing else, it will be interesting..."
          ______________________________________________
          1979 XS1100SF
          1972 XS2 650
          Ozark, Alabama
            • 9980
            Be afraid.......be very afraid..
            • Barnfresh
              • Mar 2009
              • 160
              • Abilene, TX
              Both seals were leaking when I got my used engine. The alternator side was oozing brown foam and the left side leaked pretty good. I ordered National seals in these sizes. When I tore the alternator side down it was all dry inside and the oozing had stopped. I left it alone as it seemed to cure itself. I checked endplay and replaced the left side. Did good for a while but guess what...
              When the horse is dead, dismount.
              Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
              • Jamie
                • Aug 2010
                • 182
                • Norman, OK
                If you need any seals let me know. I have fought this problem for the last several weeks. Here is what I know, the 32x45x7 will fit but will leak/fail after some time, the OEM dimensions are: 32x48x7.
                I have been trying all sizes until I finally found the one that worked. Go figure, the Yamaha dealership had them in stock. Part number is: 93101-32087-00.
                Jamie
                • Joab
                  • Aug 2010
                  • 472
                  • Ozark, Alabama
                  Jamie
                  Arnt the seals from Yamaha the ones you have to split the case to install?
                  Joab
                  1979 XS1100SF
                  1972 XS2 650
                  Ozark, Alabama
                  • Barnfresh
                    • Mar 2009
                    • 160
                    • Abilene, TX
                    I'm not splitting the cases... I'll just keep getting new left boots...
                      Yes, the original seals to this bike require the cases to be split to install. The ones that are pressed in without splitting are aftermarket, not really intended for this engine.
                      • BillyRok
                        • Aug 2011
                        • 420
                        • Shortsville, NY.
                        If the original seals require splitting the cases to install them, do you have to split the cases to remove leaky originals?
                        Billy
                        • Jamie
                          • Aug 2010
                          • 182
                          • Norman, OK
                          No, absolutely no splitting the cases to install the Yamaha oil seal I mentioned in my previous post. This is the Yamaha oil seal that goes on the left side (field coil, pickup coil). I installed in 5 minutes and no more pesky, irritating oil leak around the crankshaft.
                          Jamie
                          • BillyRok
                            • Aug 2011
                            • 420
                            • Shortsville, NY.
                            But is there a trick to taking out the factory seals with the flange without splitting the cases?
                            Billy
                              • 8659
                              Just pry/cut it out with a screwdriver and a pair of dykes.
                              • Jamie
                                • Aug 2010
                                • 182
                                • Norman, OK
                                Yep, like he said. I used a very sharp edges flathead and pryed the old (leaky) one out and then installed the new OEM. Pretty damn easy, and finally no more oil leak.
                                Jamie
