Oil Seal
  • Joab
    • Aug 2010
    • 472
    • Ozark, Alabama
    Oil Seal
    So, here is the oil seal I got from Napa. It seems a little small on the outside diameter, Do I just fill in with RTV, or do I need to go find a different seal from somewhere else?
    Joab
    "If nothing else, it will be interesting..."
    ______________________________________________
    1979 XS1100SF
    1972 XS2 650
    Ozark, Alabama
    Did it fit in there TIGHT? Did you have to drive it in or did you just push it in?
    • Joab
      • Aug 2010
      • 472
      • Ozark, Alabama
      It is tight to the crankshaft, loose on the outside. I just pushed it on. You can see on the pic it isn't really even touching on the outside...
      Joab
      1979 XS1100SF
      1972 XS2 650
      Ozark, Alabama
        Find a different seal. The oil pressure will blow it out. It has to fit tight in the case and around the crank.
          What is the size of the seal that you used? Correct size should be 32x48x8, 32 being the ID, 48 being the OD, and 8 is depth, all in MM.
            Thanks Phil. Tod knows the actual part number but he is gone again on one of his frequent vacations.
            • Joab
              • Aug 2010
              • 472
              • Ozark, Alabama
              That is the size seal Napa ordered for me. And they were the only auto parts store around here that didn't give me a blank look when I asked for one. Everyone else apparently cant order anything without a vehicle reference to look up in their computer.
              Joab
              1979 XS1100SF
              1972 XS2 650
              Ozark, Alabama
                http://www.summitracing.com/parts/TMK-32X48X8/
                  Double check the seal, the numbers should stamped on it. Sometimes parts can end up in the wrong packages.
                  • Joab
                    • Aug 2010
                    • 472
                    • Ozark, Alabama
                    Thanks Greg, new Oil Seal is on order. It is a special order part, so I will let you know in a couple weeks when it arrives how it all works out.
                    Joab
                    1979 XS1100SF
                    1972 XS2 650
                    Ozark, Alabama
                      I hope Phils dimensions are right because that is how I looked it up.
                      • Joab
                        • Aug 2010
                        • 472
                        • Ozark, Alabama
                        If not, I will have a fine start in opening a museum dedicated to all the oil seals that do not fit an XS1100 :P
                        Joab
                        1979 XS1100SF
                        1972 XS2 650
                        Ozark, Alabama
                          Greg, yep that is the correct size for the ignition side seal, the alt. side seal has a smaller OD, 45MM.
                          Joab, any good bearing shop should have that seal on the shelf if you don't want to wait for special order to arrive, JAT
                            LOL... they might fix the front wheel seals on your 77 Ford Pinto.
                              More technical info...
