Oil Seal
  • Joab
    • Aug 2010
    • 472
    • Ozark, Alabama
    Oil Seal
    So, here is the oil seal I got from Napa. It seems a little small on the outside diameter, Do I just fill in with RTV, or do I need to go find a different seal from somewhere else?
    Joab
    "If nothing else, it will be interesting..."
    ______________________________________________
    1979 XS1100SF
    1972 XS2 650
    Ozark, Alabama
    • 9980
    Did it fit in there TIGHT? Did you have to drive it in or did you just push it in?
    • Joab
      • Aug 2010
      • 472
      • Ozark, Alabama
      It is tight to the crankshaft, loose on the outside. I just pushed it on. You can see on the pic it isn't really even touching on the outside...
      Joab
      1979 XS1100SF
      1972 XS2 650
      Ozark, Alabama
        • 9980
        Find a different seal. The oil pressure will blow it out. It has to fit tight in the case and around the crank.
          • 8802
          What is the size of the seal that you used? Correct size should be 32x48x8, 32 being the ID, 48 being the OD, and 8 is depth, all in MM.
            • 9980
            Thanks Phil. Tod knows the actual part number but he is gone again on one of his frequent vacations.
            • Joab
              • Aug 2010
              • 472
              • Ozark, Alabama
              That is the size seal Napa ordered for me. And they were the only auto parts store around here that didn't give me a blank look when I asked for one. Everyone else apparently cant order anything without a vehicle reference to look up in their computer.
              Joab
              1979 XS1100SF
              1972 XS2 650
              Ozark, Alabama
                • 9980
                  • 8802
                  Double check the seal, the numbers should stamped on it. Sometimes parts can end up in the wrong packages.
                  • Joab
                    • Aug 2010
                    • 472
                    • Ozark, Alabama
                    Thanks Greg, new Oil Seal is on order. It is a special order part, so I will let you know in a couple weeks when it arrives how it all works out.
                    Joab
                    1979 XS1100SF
                    1972 XS2 650
                    Ozark, Alabama
                      • 9980
                      I hope Phils dimensions are right because that is how I looked it up.
                      • Joab
                        • Aug 2010
                        • 472
                        • Ozark, Alabama
                        If not, I will have a fine start in opening a museum dedicated to all the oil seals that do not fit an XS1100 :P
                        Joab
                        1979 XS1100SF
                        1972 XS2 650
                        Ozark, Alabama
                          • 8802
                          Greg, yep that is the correct size for the ignition side seal, the alt. side seal has a smaller OD, 45MM.
                          Joab, any good bearing shop should have that seal on the shelf if you don't want to wait for special order to arrive, JAT
                            • 9980
                            LOL... they might fix the front wheel seals on your 77 Ford Pinto.
                              • 8802
                              More technical info...
