So, here is the oil seal I got from Napa. It seems a little small on the outside diameter, Do I just fill in with RTV, or do I need to go find a different seal from somewhere else?
Oil Seal
Did it fit in there TIGHT? Did you have to drive it in or did you just push it in?Greg
It is tight to the crankshaft, loose on the outside. I just pushed it on. You can see on the pic it isn't really even touching on the outside...Joab
"If nothing else, it will be interesting..."
______________________________________________
1979 XS1100SF
1972 XS2 650
Ozark, Alabama
Find a different seal. The oil pressure will blow it out. It has to fit tight in the case and around the crank.Greg
Thanks Phil. Tod knows the actual part number but he is gone again on one of his frequent vacations.Greg
Originally posted by bikerphil View PostWhat is the size of the seal that you used? Correct size should be 32x48x8, 32 being the ID, 48 being the OD, and 8 is depth, all in MM.Joab
1979 XS1100SF
1972 XS2 650
Ozark, Alabama
Thanks Greg, new Oil Seal is on order. It is a special order part, so I will let you know in a couple weeks when it arrives how it all works out.Joab
1979 XS1100SF
1972 XS2 650
Ozark, Alabama
I hope Phils dimensions are right because that is how I looked it up.Greg
Originally posted by BA80 View PostI hope Phils dimensions are right because that is how I looked it up.Joab
1979 XS1100SF
1972 XS2 650
Ozark, Alabama
Joab, any good bearing shop should have that seal on the shelf if you don't want to wait for special order to arrive, JAT2H7 (79)
3H3
Originally posted by Joab View PostIf not, I will have a fine start in opening a museum dedicated to all the oil seals that do not fit an XS1100 :PGreg
