Does anyone have the bearing #'s for the steering head bearing but not the yamaha #'s but the #'s on the bearing themselves or even the sizes. I am looking for some bearing and I am trying to locate some before saturday. thanks in advance for your help.
Steering Head Bearing
Tags: None
I have the sizes, and you should be able to cross them to a local supply.
25 X 47 X 15 mm for the upper, and 30 X 55 X 17 for the lower. You wil need a seal, if you can find it, but I don't have that size.Ray Matteis
thanks for the bearing sizes diverray. I did some searching on the net, for the part # with the sizes you posted, and from what I have found is the bearing #'s are 32005 and 32006. I hope this is correct, tomorrow I will try to see if I can find some locally.'79 XS11SFComment
If I remember I will look at my old bearings when I get home and see if there are numbers on them.Nathan
Theodore RooseveltComment
☮Comment
thanks for the replies today I picked up some new timken bearing br32005 and some br32006 that are the same measurements as the originals.'79 XS11SFComment
☮Comment
not really, 20 bucks each fairly cheap for a good quality bearing, the bearings that were in my bike were dry and needed to be replaced.'79 XS11SFComment
