Steering Head Bearing
  • trdriver71
    • 360
    • Edmonton Alberta
    Does anyone have the bearing #'s for the steering head bearing but not the yamaha #'s but the #'s on the bearing themselves or even the sizes. I am looking for some bearing and I am trying to locate some before saturday. thanks in advance for your help.
    '79 XS11SF
  • GARTHXS
    • 1631
    • Seattle
    Bike bandit sells all balls sets
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
      I have the sizes, and you should be able to cross them to a local supply.
      25 X 47 X 15 mm for the upper, and 30 X 55 X 17 for the lower. You wil need a seal, if you can find it, but I don't have that size.
      • trdriver71
        • 360
        • Edmonton Alberta
        thanks for the bearing sizes diverray. I did some searching on the net, for the part # with the sizes you posted, and from what I have found is the bearing #'s are 32005 and 32006. I hope this is correct, tomorrow I will try to see if I can find some locally.
        '79 XS11SF
          If I remember I will look at my old bearings when I get home and see if there are numbers on them.
            Upper bearing is 32005JR 25X47X15
            Lower bearing is 32006JR 30X55X17
            The All Balls set P/N 22-1004 is good quality, and they come with the seals.
            http://www.allballsracing.com/22-1004.html
            • trdriver71
              • 360
              • Edmonton Alberta
              thanks for the replies today I picked up some new timken bearing br32005 and some br32006 that are the same measurements as the originals.
              '79 XS11SF
                Those must have set you back a bit.
                • trdriver71
                  • 360
                  • Edmonton Alberta
                  not really, 20 bucks each fairly cheap for a good quality bearing, the bearings that were in my bike were dry and needed to be replaced.
                  '79 XS11SF
