What did I just do... timing
  • JScro
    • Feb 2012
    • 70
    • Austin, Tx.
    So I've still go my ever present oil leak from the left side. I decided to be brave, remove the timing mechanism and replace the seal. I marked the screws, and the timing plate. Got the seal replaced pretty easy, put everything back together.
    Then I went to start it, once. It made a funny noise, and now the timing plate is about 180 degrees from where I marked it.
    Uhhh... what did I just do and what do I do to fix it?
    • 9981
    Did you get this pin.....
    Lined up properly with this groove?......
    • JScro
      • Feb 2012
      • 70
      • Austin, Tx.
      I did, actually double checked that.
        • 9981
        What kind of "funny noise"?
        • Rasputin
          • 3193
          • Lacombe, Alberta, Canada
          Then most likely the timing plate is installed 180 degrees off. It does have a slight difference but can be put in wrong.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
            • 9981
            Possible but it would have to be forced Doug. The slot is offset to one side.
            • Rasputin
              • 3193
              I agree Greg but some members have pulled it off. So it was JAT to check.
              2-79 XS1100 SF
              • JScro
                • Feb 2012
                • 70
                • Austin, Tx.
                The screws and timing plate were definitely put back on where I marked them. Normally the bike cranks instantly, so the noise was just the bike hiccuping and not starting.
                I guess what I'm wondering is how should I go about getting the timing plate back to where it was marked.
                  • 9981
                  By the timing plate do you mean the round plate with the marks on it or the breaker plate that the pickup coils are mounted to.
                  • JScro
                    • Feb 2012
                    • 70
                    • Austin, Tx.
                    The round plate with the marks.
                      • 9981
                      That plate is supposed to spin when you turn the engine over. Is it on there correctly and tight?
                      • JScro
                        • Feb 2012
                        • 70
                        • Austin, Tx.
                        LOL. Seriously? Guess I'm going to go back out and try to start it again and try to forget how stupid I feel right now.
                          • 9981
                          Don't worry about that, we won't LET you forget. LOL
                          No problem JS, stuff occurs.
                          • JScro
                            • Feb 2012
                            • 70
                            • Austin, Tx.
                            Alright, so it will not start. It cranks, and it sputters a bit if I get it a little gas. However, it doesn't even start to turn over.
                            • Rasputin
                              • 3193
                              Sorry if you think I am being rude but ... "Cranks and sputters" is not the same to us as "doesn't even start to turn over".
                              If you could be a tad more descriptive of the problem we would (possibly) not be telling you to check if it is seized because it will not "turn over" as opposed to it does crank over but "I have no spark on any piston". I know if I follow the thread I will have the general idea, but it is suprising how simple wording can change the whole theme of a thread. JAT
                              2-79 XS1100 SF
