What did I just do... timing
    • 5061
    Make sure that nothing is bent and that the timing plate moves freely.
    • JScro
      • Feb 2012
      • 70
      • Austin, Tx.
      No worries man, sorry I'm probably not describing it well. So here's a video for the audio of what I'm talking about. You can hear me starting it, and it sputtering when I give it gas.
      http://www.flickr.com/photos/jscro/6949157190/
      • DAVINCI
        • Jan 2011
        • 1048
        • Cedar Mountain, NC
        Did you, by any chance remove the pickups from the baseplate? If so, your gaps will be wrong.
        Or, did you disassemble the rotor / advance mechanism to clean and lube it? If you did you can install the rotor 180 degrees out of time. I've done it so I know how easy it is!
        • TADracer
          • 1417
          • Kenner, Louisiana USA
          Reluctor???
          Originally posted by JScro
          Alright, so it will not start. It cranks, and it sputters a bit if I get it a little gas. However, it doesn't even start to turn over.
          When you pulled the timing plate off did you remove the reluctor (thats the part with the two slots that pins on the weight arms fit into)? It sounds like maybe that part is on 180 degrees out. If it is backwards then the reluctor (the little bump on the shaft) will trigger the pick-up coils out of sequence causing exactly what your problem is.
          Mike Giroir
          79 XS-1100 Special
          • DAVINCI
            • Jan 2011
            • 1048
            There's an echo on the internet
            • JScro
              • Feb 2012
              • 70
              • Austin, Tx.
              So looks like i'm taking it all apart and rechecking my work this evening. I basically removed the thing following the Clymers manual so I didn't remove the pickups. Considering I know very little about what I'm doing, it's pretty likely I got something wrong putting it all back together. I bet the beer didn't help.
                • 9980
                So looks like i'm taking it all apart and rechecking my wiork this evening. I basically removed the thing following the Clymers manual so I didn't remove the pickups. Considering I know very little about what I'm doing, it's pretty likely I got something wrong putting it all back together. I bet the beer didn't help.
                What kind of beer? I hope you were drinking the proper kind, the wrong kind can cause problems like this.
                • JScro
                  • Feb 2012
                  • 70
                  • Austin, Tx.
                  When working outside in Texas, we usually hydrate with Lonestar like it's water.
                  Took everything apart, got it back together, and it started fine.
                  • Dragon Tamer
                    XStremely XSive(Deceased)
                    • Sep 2006
                    • 426
                    • Half way between Chili and Winter Wisconsin.
                    I lived in Texas for a while so I know for a fact that Lone Star has the wrong scientific molecular weight for working on a motorcycle. It is not in sync with the electron flow and magnetic field of the universe.
                    Try something with a different sectional density, like Fosters or Leinenkugels. Beer of this type will cause you to make mistakes of the VERY large and stupid type so you can just take a quick look in the morning and see what it is rapidly.
                    The Old Tamer
                    _________________________
                    1979 XS1100SF (The Fire Dragon)
                    1982 650 Maxim (The Little Dragon)
                    another '82 650 Maxim (Parts Dragon)
                    1981 XS1100SH (The Black Dragon)
                    If there are more than three bolts holding it on there, it is most likely a very important part!
