Pacifico Fairing
  • barrelguy
    • 169
    • Oliver, BC
    Pacifico Fairing
    Are these plastic or fiberglass? May sound like a dumb question but I believe there is a difference in how these materials can be restored. Fiberglass has a gelcoat (?) Any insight would be helpful as this is the last bit of my winter pretty-up project. Thanks
    1980 XS 1100 Special
    Mostly stock & original
    Added Yamaha fairing (w/ 8-track!)
    Torpedo bags
    New paint (still) pending
    Stainless brake lines
    Tkat forkbrace
    Coils from Honda 1000
    Previous bikes:
    1968(?) 350 Harley Davidson
    1977 Yamaha 650
    They are 2 different kinds of plastic. The black part is a ABS plastic. The painted part is some other kind of plastic. I welded up some cracks on mine and the 2 plastics reacted differently to the heat. The black plastic melted better and the white plastic bubbled and started to burn way quicker.
      Looking at the one I've got, it appears to be a reinforced plastic rather than a straight plastic. Doesn't look like fiberglass to me....
        Absolutely not fiberglass.
        • barrelguy
          • 169
          • Oliver, BC
          Thanks all. I'll proceed based on plastic.
          Torpedo bags
          Tkat forkbrace
          Previous bikes:
          1977 Yamaha 650
          • Poprock
            • Apr 2005
            • 594
            • Oregon Coast
            My Pacifico cracked up. I repaired it using ABS glue like for plumbing. Sand to bare, glue, fiberglass cloth, ABS glue again to saturation. Don't do it in your basement. It'll harden up real nice and make a tight unit. I even pieced in pieces of ABS pipe that were heated in boiling water and flattened out. You'll need to put some kind of filler on later so you can sand to smooth and repaint. Haven't gotten that far with mine yet.
