Originally posted by motoman
View Post
What octane fuel do you run in your XS
Brent in GA
It's been said, but it's the middle of winter and needs to be beat again like the proverbial horse to get us through 'til spring...
Unless your engine is really out of whack or the compression has been upped, it is a sure way to spend more than you need to by using premium, and as has been proven to carbon up the exhaust valves. Just don't get the obsession with premium...
The bike ain't some little sweetheart you are trying to woo at the bar with fancy drinks fellas, it's mechanical and runs best on the lowest ocatne it will use without ping/knock. I highly doubt any XS needs premium despite our desire to feel like we are doing something good for the bike, when we really aren't at all.Howard
ZRX1200
Octane
Regardless of what octane I may choose to use, I will NOT leave in ANY tank fuel with ethanol in it. If there is no choice of buying E0, I will run E10 unwillingly, but it will not be left in the tank or any part of the fuel system for more than a week. If I do not ride during that week, it will be pumped/drained out. This goes for any internal combustion engine that I own whether it be a tool or off road vehicle. The exception is fuel injected cars and trucks. They are the only thing that I will leave fuel with ethanol in.
I went on a 2 day ride a while back. First day was E10 regular - 36 MPG. Second day (similar riding conditions) E0 premium - 42 MPG plus seat of the pants feel - better performance. Whether it was the E0 by itself or the combination of it and the higher octane is anyone's guess. Either way, the bike and I both liked it. I do not think that higher octane fuel in our 11s hurts anything at all.
Even our "know all" government is (finally) realizing that ethanol is NOT good.
I know we all have seen the fuel requirement printed on the decal inside of the side cover. Last one I read said 91 Octane leaded? JMHO1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
Mike
.........and that rating was based off a totally different RM formula back then. Higher the octane....higher the ignition point, which in the case of most any internal combustion engine with a 10:1 compression ratio or lower does NOT require. For example, the Honda ST1300 with its 13:1 compression ratio IS required to run premium fuel.
The only instance I've heard of premium fuel being of benefit in an XS11 motor is from 3Phases some 7300mi. ride this past fall. He told me, thru a couple areas headed east on I-40 where outside temps were fairly high and cyl. temps were higher than normal runnin' a constant 5K on the slab, premium would ignite good getting a full burn and noticed a bit higher mileage and seat of the pants power increase, otherwise he just burned what was cheapest.
IMO, that's an exception to the norm that these bikes are normally ridden. Otherwise, your just fooling yourself and making your fuel cost higher and your pocketbook lighter.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Tell Me More
Originally posted by jetmechmarty View PostTell me more!
The environmentalists stepped in and proved that ethanol is NOT good for the environment as we once thought it was.
So the E15 got shut down - at least temporarily. One major concern was the dispensing of E15. For example: a typical gas pump with one hose dispenses 3 different grades of fuel. Each time you pump fuel, you get at least 1/3 gallon of what was pumped before you. Not a good enough method of dispensing E15.
The business that has benefited the most from ethanol in fuel is the automotive service industry. They have enjoyed a major increase in revenue repairing vehicles with ethanol related problems.
I have been told by more than one motorcycle/ATV/water sports dealer that 95% of their fuel system repairs are caused by ethanol.
MikeLast edited by MPittma100; 01-12-2014, 09:36 AM.1981 XS1100H Venturer
K&N Air Filter
ACCT
EBC Front Rotors
Mike
Originally posted by motoman View PostI know we all have seen the fuel requirement printed on the decal inside of the side cover. Last one I read said 91 Octane leaded? JMHO
As far as high compression engines only needing premium, I have owned a 2002 Jeep Grand Cherokee with 9:1 compression, and a 2002 Pontiac with 9.5:1 compression. Both vehicles required premium fuel. I do not consider either of these "high" compression.
There are just as many opinions/arguments for either of the octanes. I would guesstimate that each of us will burn what they like the most.1981 XS1100H Venturer
K&N Air Filter
ACCT
EBC Front Rotors
Mike
Mike,
I don't recall when the change happened, but research octane used to be posted on our gas pumps. That's how it was back in the 60's. It is the least severe fuel rating. Motor octane is the most severe rating. Since some time in the 70's, we've been using R+M/2. Yamaha did not specify how the desired octane rating is achieved.
Read more here: OCTANE RATING
E15 is a problem, and most manufacturers have stated so. The main problem is, our dear leaders have mandated that "X" amount of ethanol is to be used as fuel additive per year. The dilema? We aren't burning enough fuel to where that much will be used in just a 10% mix.
As stated, they've backed off the E15 for the time being, but the AMA is actively asking people to write everyone they can to ask for a permanent ban on anything above a 10% mix.Try your hardest to be the kind of person your dog thinks you are.
Article
Here is an article that helps explain octane ratings then and now:
http://www.economist.com/blogs/babba...octane-ratings.1981 XS1100H Venturer
K&N Air Filter
ACCT
EBC Front Rotors
Mike
Fuel
The article makes reference to the amount of energy per gallon. Usually it is stated as energy per pound of fuel. And when used in an engine it is the percent of energy obtained from the fuel. Modern vehicles are around 35%. Some big ship engines are at 50%
Back in the seventies Axtell in CA would test the different brands of fuel to find out which was making the most horsepower that week. They had a 750 Norton engine of well known performance parameters connected to the dyno.
Previously in this thread the burn rate of the fuels was well discussed. The type of ignition and the plugs, along with the fuel supply system, are all part of the equation. But rather than getting high tech, my theory is: If it runs fine on the cheap stuff, that is what I will use. My friends at the Rolls Royce ( remember the no lead scare ) agree. And lastly. My 1941 Ford tractor now has electronic ignition. No more points and condensor.
Unkle Crusty
Here's a link that will explain the different octane ratings...
http://retail.petro-canada.ca/en/independent/2069.aspxFast, Cheap, Reliable... Pick any two
