Would there be any interest in a 'definitive' parts interchange guide tech tip? These questions come up on a regular basis, and it can get pretty confusing if you're not aware of some of the minor and major differences between models...
Parts Interchange Guide?
70YES! I want to know what fits what!94.29%66I don't care, I'm chopping it anyway...0.00%0The parts are all different??!!1.43%1It's more fun to guess...4.29%3Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone...Tags: None
I think I would take some time to really compile it. Might have to be a sticky and just let it evolve from there part by part.Nathan
No, this probably won't be something whomped up overnight....Fast, Cheap, Reliable... Pick any two
...but it shouldn't be as bad as you might think. A fair chunk of this info is already posted somewhere on this site, so a guide could be 'shrunk' a bit by providing links to some of the stuff that's covered. And if it's limited to fit/function, that would rule out the differences that are only cosmetic. And you'd have to limit it to US models only, because trying to figure in the 'world' versions would make it hopelessly confusing for most members. Or maybe some non-US members would like to cook up the guides for their models?Fast, Cheap, Reliable... Pick any two
I think it would be a GREAT idea! listing things like wheels, TCI, Timing parts, camshafts, valves, fenders, sidecovers, etc. would really answer a lot of questions for a lot of people trying to do restorations. However, a lot of this information is available on the benefiscal site. Under each part number, it states what models the part is used on.
There may be times when certain parts may have different part numbers, but will still fit the function on a different model. For example, the brake pedal on the LH is a unique part number, as is the same pedal on the LG. However, if I'm not mistaken, its the same shape as all the other models' pedals, even though the part number for the brake pedal on the E, F and G is different from that of the SF, SG, H and SH. That's 4 different part numbers for the same part - 2 of them are just painted black.1980 XS850SG - Sold
Originally posted by CatatonicBug View PostThere may be times when certain parts may have different part numbers, but will still fit the function on a different model. For example, the brake pedal on the LH is a unique part number, as is the same pedal on the LG. However, if I'm not mistaken, its the same shape as all the other models' pedals, even though the part number for the brake pedal on the E, F and G is different from that of the SF, SG, H and SH. That's 4 different part numbers for the same part - 2 of them are just painted black.Fast, Cheap, Reliable... Pick any two
Great idea Steve.
What my also be a helpfull is to make it flexible enough to include linkage to items that can be easily modified to fit certian models. Like for instance MIKES XS has the handlebar switches that can work with rewiring, Those things that are near impossible to find now are arlso quite common questions that pop up and someone here always has the answer.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
This sounds like a project equal in difficulty to writing an encyclopedia.Greg
No, it doesn't have to be that detailed....But it would be nice to have kind of a 'quick reference guide' to at least point you in the right direction. I don't know if linking to particular parts suppliers would necessarily be helpful as they do change things from time to time and finding dead links is frustrating.
Last edited by crazy steve; 04-05-2012, 06:07 PM.Fast, Cheap, Reliable... Pick any two
perhaps just list the changes and differences for each year/model, then let people figure it out for themselves.1979 xs special, just finished the top end rebuild and then i still have lots of work.
progress thus far...
http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
"If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
Why go thru all the trouble... I can just post my question and it will get answered by you Steve
Sounds like alot of work. I wish you luck my friend. I voted I'll just guess, so I can help you from having to write something as complex and hard to understand as the King James Bible....Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
2005 V-Star 1100 Classic
I'm waiting for the flood of 'I'm chopping it' votes to come in....Fast, Cheap, Reliable... Pick any two
Great idea, Steve.1995 KZ100P
Pods, jets, pipes, cam adjuster, oil cooler
1977 Ironhead - custom build
Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
I would have thought anyone chopping their bike would care lots what parts would fit from other models.
The folk I'd have thought wouldn't care are the original restorers, why would they want to know what none original part would fit their bike.
Anyway great idea.Tom
Originally posted by crazy steve View PostI'm waiting for the flood of 'I'm chopping it' votes to come in....
SEE.......see what you've gotten yourself into?Greg
