You could take the rotor completely off and ride it a short distance on just the battery power to check. Just remember to put the stator cover back on before you start the engine so you don't blow the oil galley plug and oil across the garage.
engine vibration
exactly what i was going to try greg. :-)
other than that and what ron suggested i cant think of anything
else to try except for tearing into it.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Good luck Pete. Hopefully you'll find the rotor out of balance or bent and it'll be an easy fix.
Keep us posted. I'm interested in learning what you find.Greg
pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Hi was wondering if you found out what the problem was just would like to know.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
Yeah.......what he said!
i havent spent much time on it,
ive lost motivation with it,
i took out the top engine mounts
and removed the 'outer sleeve' made
a bit of difference, couldnt get the others out
with out disconnecting the final drive,
and breaking my back,
havent been bothered stuffing around with it any more,
made a bit of difference, its got the vibration
between 3500 - 4500, but its more ridable.
im in the process of selling it all up and looking
at updating to something much newer.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
I had a bearing go bad on the shaft the clutch basket sits on. It had a funky vibration and knocked out the little bearing on the clutch cover also. Unfortunately, this was a case-splitting issue to fix.
Hate to hear of you giving up on it..
hey tod,
thats where i think my problem is, before changing out the clutch
basket, fibres and steels, the bike was unridable,
its better but not right, the clutch also chatters slightly in use.
ive got 3 engines sitting here, they all need to have the cases
split with different problems to be repaired.
pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Have you taken the valve cover off and verified cam timing? if its way retarded or advanced it can cause cylinder mix up @ high rpm and full ignition advance... JATDon
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
2005 V-Star 1100 ClassicComment
hey don,
yep was 1 of the 1st things i looked at before starting
the engine, the cam caps were on back to front but
other than that the timing is sweet, thanx anyway.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
hmmm... well..... sounds like a balance issue somewhere then. or the ignition is getting way pissed as it advances. Dunno buddy. Hope you figure it out.Don
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
