engine vibration
  • petejw
    • 2269
    • sydney australia
    engine vibration
    ive swapped over engines and fitted
    a 3x1 with a mechanical advance and 2h7 tci
    from my 5n5 engine that was fitted with a 4ro tci,
    the bike pulls hard to redline but the engine vibrates
    pretty bad from around 4000 rpm to redline,
    any thoughts on what could be causing it,
    the engine has been tuned and synced, the mech adv
    is free, the engine idles well and runs well till the vibration
    kicks in.
    tia.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • 9980
    Check your engine mounts Pete. The engine is probably touching the frame somewhere.
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Pete if you can not find any place the engine is touching the frame try running the bike in neutral and use a Stethoscope if you do not have one small piece of PVC pipe on the engine in several places may help to isolate the noise. You may find its exaust or something else vibrating.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
        I find that on my current SH with the exhaust system on it, right about 4k it starts to put off more vibration. I can hear it in the exhaust tone as well. It seems to lessen alot above 5k.
        • DAVINCI
          • Jan 2011
          • 1048
          • Cedar Mountain, NC
          Pete, have you checked the timing with a light? You may have too much initial advance??
          • petejw
            • 2269
            • sydney australia
            sorry havent been on for a few days,
            thanx for the replys,
            the vibration is pretty full on, in that i cant
            ride the bike after it hits 4000rpm, it feels like
            something is out of ballance, the clutch was slipping
            so i tore into that hoping something might be wrong there,
            replaced the clutch basket and insides, it helped a little
            but not much, the other thing i was thinking it could be
            the rotor, but the bikes charging fine i cant see what could
            go wrong with that.
            greg, i resleeved the engine mounts with an inner tube,
            the mounts are in tite there not hitting the frame, i could remove
            the inner tube and put the mounts back in, but when it was mounted in the other bike i could still feel the vibration just not as bad.
            randy, ive set the initial timing at 10 degrees, i could drop it back to
            5, but its not pinging so id think that should be fine.
            don, was thinking the same thing i had a 4 -1 jardine on it, then swapped
            it out with a 4-2-1, the problem is the same.
            ron, ive got a stethoscope but the engine isnt making a noise as such
            and the vibration doesnt come into it till 4000rpm other than that it idles
            nicely.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • James England
              • 3039
              • North of England
              What do you mean by "inner tube"? Surely not an inner tube from a wheel?
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                Pete I have a hard time trying to visualize the vibration. Can you duplicate it sitting on the stand.
                If it does it sitting on the stand out of gear its the engine and typically the balance is threw the crank shaft. The only things that I know can change the balance is rods or pistons or a differential of power. If there is a delay in firing of cylinders or severe difference in power from a cylinder that can cause a vibration that will increase with rpm. If no rods or piston changes and you do not have noise or nock at low rpm then I'd try an unothadox method and run for a few seconds on only 2 cylinders then switch to the other 2 and see if that identifies a difference or starting point.
                If it only does it in gear with the rear wheel spinning you have a different direction to go.
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                • petejw
                  • 2269
                  • sydney australia
                  hi james,
                  thats exactly what i mean, i used a bicycle inner tube
                  slid over the worn rubber engine mounts, sprayed some
                  silicone over it and slid them into the engine, ive done it before
                  with good results, do u see a problem with this?
                  hey ron, the whole bike shudders under load, from around
                  3500-4000rpm
                  it also does the same thing in neutral but not as bad,
                  ive never felt anything like it before, the bike has power
                  and making no noises or knocks, thats y i thought the crank
                  and bearings should be ok.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • James England
                    • 3039
                    • North of England
                    Originally posted by petejw
                    hi james,
                    Right. I thought you meant that you had entirely replaced the OEM mounts with inner tube (maybe rolled up). No, I don't think this will be the cause of your vibration then.
                    Mostly, I've found the vibes usually are most noticeable at 4,000rpm+ on these bikes, sometimes enough to whiten fingers.
                    Have you checked the pickup wires, plugs, coils etc? I wonder of you have a misfire at 4,000rpm+ ?
                    • petejw
                      • 2269
                      • sydney australia
                      lol thats funny, no i still used the original rubber mounts,
                      my other engines have had the vibration at 4000rpm, but this
                      is much more, the whole bike shakes to the extent u cant ride it,
                      the engine isnt missing and the plugs look fine, it idles fine too,
                      im going to check the rotor out, but i cant see that being a problem.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        Pete as James had mentioned that is where I was going with this because if you do not hear a knock and no noise it has to be a power differential. If it was a fuel problem it seems like it would be seen sooner. That is why I thought trying to run on 2 cylinders at a time might tell which circuit to look in. After you identify if its 1 & 4 or 2 & 3 you can further make sure ist not a fuel problem by switching electronics and see if it follows the electronics. I know shade tree approach but its really hard to isolate without an analizer to look at power output. I can't even think at 4000K anymore.
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
                          • 9980
                          Do you know any history on this engine Pete? Did you take it out of another running bike or did you get it not running? What I'm getting at is did the vibration exist before you got it? If the vibration is as bad as you say it wouldn't have been ridden before I would think.
                          If it seems like a balance issue The first thing I would do is check everything I bolted to the crankshaft. Make sure it's not something I did. These engines are internaly balanced so unless the crankshaft is way out of balance, which is highly unlikely unless the engine was rebuilt and the balance counter weights on the crank were messed with, it's going to be something external. I would think most likely the rotor for the alternator.
                          Just thinking out loud, so to speak.
                          • petejw
                            • 2269
                            • sydney australia
                            i can give it a go ron,
                            cant hurt hey.
                            its improved slightly after i changed out the clutch,
                            i know there are some roller bearings fitted near the transmission
                            was thinking if those bearings might have collapsed it could
                            cause the problem.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                            • petejw
                              • 2269
                              • sydney australia
                              greg, it was a parts bike i picked up that had been sitting for a cpl
                              of years, was originally fitted in a standard, the po had butchered it
                              a fair bit tho, trashed the wiring loom, wrong length spark plugs fitted
                              cam caps fitted in wrong order and facing wrong way, looks like
                              he'd been in the clutch before as well, so who knows what else
                              he had done to it,
                              anyway i put it all together and
                              got it running, it had a vibration when i rode it, but nothing like it
                              has now since i swapped it out and sleeved the rubber mounts the
                              vibration was way more.
                              i was thinking the same, the crank shaft is drilled for balance, so its
                              not like a weight has flung off and caused it to be out of balance,
                              im going to check the rotor tomorrow, but i cant see anything that
                              could go wrong with it, if it was running 'crooked' then i would think
                              it would rub/hit the stator, theres no oil leaking out from the crank
                              seals.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
