Acceleration Loss
  • mmaddix
    • Jul 2011
    • 232
    • Beaufort, SC
    Thank you all.
    I will look into new springs and adjust the cable. And I will try the full synthetic with new springs, mainly because I just spent 50 bucks on royal purple 20w50 that I wanted to try out, but if it still does it or it does it again down the road I guess I will have to say bye bye to the synthetic
    Thanks again tho.
    USMC 2005 - Present
    79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
    78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
    • GARTHXS
      • 1631
      • Seattle
      Yeah get rid of the synthetic
      91 kwaka kz1000p
      Stock
      ( Insert clever quote here )
        • 9980
        Originally posted by mmaddix
        Thank you all.
        Thanks again tho.
        I use Royal Purple 75w140 full synthetic in the middle and final drives because steel gears are steel gears and it is a superior lubricant. I don't believe it's compatable with 30 year old friction discs though.
        IMHO
          • 5055
          Originally posted by skids
          Possibly too lean? Floats set for economy? Aftermarket exhaust and/or mods to the air filters without enough jetting compensation?
          My bad. I missed the part about increasing rpms.
          • mmaddix
            • Jul 2011
            • 232
            • Beaufort, SC
            Well I couldn't find springs soon enough so I just put the bike back together so I wouldn't be spending so much for gas in my truck. I adjusted the clutch cable and the mechanical adjustment. The screw for the mechanical adjustment was way to far in. well when I took it for the test ride it worked perfectly. I had better acceleration in every gear. The throttle response was awesome. It is amazing how much more power it has. Well how much more power it's getting to the back wheel anyways. It's like a whole new bike.
            Thanks again gents.
            USMC 2005 - Present
              Gald it worked out. If I might add a suggestion, get the FSM or any other manual, and go through ALL of the maintenance section adjustments and checks.
              • mmaddix
                • Jul 2011
                • 232
                • Beaufort, SC
                Thats a good idea. I cant believe I havent done this yet and the bad part is i have the manual.
                USMC 2005 - Present
