middle drive remover
  • NathanP
    • Feb 2012
    • 38
    • Olympia, WA.
    so im trying to remove the middle drive on a 78 xs motor i got all 5 or 6 outside hex bolts off it still feels like something else is holding it on there is there something im missing
    80sg (currently getting motor swap)
    Did you get the one long one that also holds the outer cover on?.....
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      There should be a total of 7 bolts holding the middle drive to the motor, including the long bolt.
      Mike Giroir
      79 XS-1100 Special
      • NathanP
        • Feb 2012
        • 38
        • Olympia, WA.
        hmm the big bolt??? i dont think so is it under a cover??
          There's four bolts holding on the middle drive cover (if this is that modified drive, it has that splined shaft sticking out); there's two close together on the bottom, the forward one needs to be removed...
          • XJfan1
            • Feb 2012
            • 180
            • Huntington,Indiana
            Lower part of the cover left bolt I believe. It is a long one. I made the that same mistake myself. did a little head scratching and got on the site to find out.
            1982 xj 1100
            "The Ape"
            http://youtu.be/AiQ8CqclHr4
              The bolts being pointed at by the 7 white arrows hold the middle drive on.
                I hope you drained the middle drive first. Even after you drain it, there'll still be some in it, and it's usually some pretty foul smelling stuff.
                • NathanP
                  • Feb 2012
                  • 38
                  • Olympia, WA.
                  oh ok thanks that picture helps alot yep she is all drained and ready to go
                    • 5050
                    Yes, good pic. One upon a time, I bought an "XS11" middle drive from ebay. I never figured out what I belonged to, but it was missing that bolt hole at the round cover area. I thought maybe it was from a Special model. It leaked and leaked all the way from denver to montana and back. Then I figured it out. You would have thought I would have figured it out when I had a bolt left over as I installed it! Stupid is, as stupid does (Forest Gump)
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      I don't know if you have a manual, but if you don't, there is a drain plug that drains the cavity in the main case that the middle drive came out of. The plug is located in a recess on the bottom of the main case. It will have gunk in it, and you might as well flush it out before you fill it back up with new oil.
                      CZ
                        • 9980
                        WTF are you talking about Brant?
                          • 9980
                          Sorry................CZ
                            • 5050
                            I believe he was talking about the middle drive drain plug.
                              Understood he was talking about the drain plug, but why would you flush something you're about to remove? Get it in your hands and clean it there.
