All the Harley's breath a sigh of relief
    #61
    It's hard to be positive, but it does look like he has the LH/XJ front calipers...
    • DRedel
      • Mar 2012
      • 119
      • New York, N.Y.
      #62
      If there is such a thing as 1982 xs midnight special then That's what it is. I always thought it was an 1981 but I looked an the title says 82. It's not an xs. The timing cover and valve cover I stole of a 79 in the woods.
        #63
        no such thing. sometimes in the past things were listed as the year it was first titled. so an '81 titled for the first time in '82 would be listed as an '82.
          Just a warning,
          Soccer4m, you or anyone do NOT want to actually RIDE the bike with MMO or Seafoam, OR leaked FUEL in the engine oil, or even just squirted into the cylinders, because it does leak past the rings and gets into the oil, and severely thins the oil and reduces is viscosity and lubricosity, and IF any LOAD is put on the engine can damage the bearings and such!
          Using these cleaning solvents should only be done while on the center stand, slowly warming up to normal temps, perhaps even a fan blowing across the engine, and just very mild 2-3k revs at most, but NO HARD RIDING or WOT revs!
          Then after 5-10 minutes of this engine running at temp is done, fully drain the oil, change the filter and put in the oil of your choice(see the numerous threads in this forum), and THEN you can enjoy the engine to it's fullest capacity...frame and suspension and brakes and tires and your skills being the only limits!
          I don't know about MMO, but I was reading a can of Seafoam the other day, and it said it's good to put in the oil for short or LONG TERM engine cleaning. But I'm like you.. It's mainly Naptha, which is the same as white gas or Coleman stove fuel, so yeah... I would hesitate about putting it in there long term, but maybe at the small amounts they say to have in there it wouldn't hurt?
          • DRedel
            • Mar 2012
            • 119
            • New York, N.Y.
            #65
            • DRedel
              • Mar 2012
              • 119
              • New York, N.Y.
              #66
              here is a pic where its tight against the bracket
              • DRedel
                • Mar 2012
                • 119
                • New York, N.Y.
                #67
                • DRedel
                  • Mar 2012
                  • 119
                  • New York, N.Y.
                  #68
                  • DRedel
                    • Mar 2012
                    • 119
                    • New York, N.Y.
                    #69
                    Here's some pics. Sorry they are a little big. I put the mmo in my oil today and let it idel for 5 or 6 min. Then pulled the plugs and put a little in. I'm gonna let it sit then change the oil and filter. Should I warm the bike up a little before I change the oil? Also take a look at my brake bracket and let me know if I have it put on wrong. Also feel free to let me know if anything else jumps out at you from looking at the pictures.
                      #70
                      Well, first you have the 'standard' XS rear caliper as used on everything except the LH/XJ, so your bike is a 'frankenbike' . And it even looks like you have all the right spacers and brackets to fit the 16" wheel, so that's good.
                      Where the trouble is I suspect is you're unlucky enough to have one of those 'oddball' rotors I've seen a few times, although this is the first slotted one I've seen. For some reason, Yamaha produced some that had a .060" deeper 'dish' than the 'regular' version, and if fitted in the wrong place this can be the result. The only way to tell is to remove it off the bike and check it. The 'standard' dimension is .750" from the wheel mounting face to the outer friction surface, the 'deep' ones are .810". If that's what you have, replacing it will fix it. You also might be able to swap it with the front rotor on the same side, pull both and see if the front is shallower. You've got some 'adjustment' available in the front forks, it will probably work there.
                      As an alternative, you could install a washer between the wheel spacer/bearing cover and the caliper bracket to move the assembly out enough to center the rotor in the caliper bracket, but you might have a hard time getting it all in between the swingarm.
                      That's what I'd try....
                      • DRedel
                        • Mar 2012
                        • 119
                        • New York, N.Y.
                        #71
                        I had to put a washer on my front left because it was smashing. Well I dident but a friend who was more gifted than I did. I'm wondering if switching the two would be my solution.
                          #72
                          If the front one is shallower, that may fix both problems....
                          • DRedel
                            • Mar 2012
                            • 119
                            • New York, N.Y.
                            #73
                            I'll try and swap them. Who knows what this thing has been through.
                            • DRedel
                              • Mar 2012
                              • 119
                              • New York, N.Y.
                              #74
                              Changed the oil after doing the mmo treatment two days ago. I took it for a short ride and it ran like ****. It was raining slash snowing so hopefully I'll get a longer ride tomorrow and it will be better after I run it for a while. If my rings are toast what would the bike be like when I'm ridding it?
                                #75
                                Well, it's rather COLD up there still, so you probably didn't get a chance to get it really warmed up. The performance will be a bit lacking...mostly reduced power and throttle response while the compression is low.
                                No aspersions to your mechanic, but next time you fire it up, get it warmed up, and then spritz some water on the pipes and see if all 4 are sizzling. If 1 or more are not sizzling, then it's not firing properly on those cylinders, and more tuning is required.
