I do not recall anything about replacement float needle valves or seats being a problem.
As to Needle position, I would set them all the same unless you know one cylinder has poor compression. If you have stock exhaust and stock air box, most find the center postion works best.
As to fluid, you can use DOT 3 or DOT 4. You do not want to put DOT 5 in a system that has had DOT 3 or 4 without a very very thorough cleaning and flushing. The DOT 5 does not work and play well with its older siblings!
Sorry to hear the PO passed away, but, at least his old ride found a new loving home first.
