fuel octane
  • mjpxs11sh
    • Jan 2011
    • 299
    • N/E, Illinois
    fuel octane
    hey all. i just happened to come across the side cover sticker on my 81SH, and it says "Regular (Leaded ) 91 Octane Min". ive been using Reg unleaded 87 Octane without any issues except probably mpg, but havent ckd as of yet.
    Max
    81 XS1100SH Black Beast Mutt
    Kerker 4/1
    stock carbs and air box.
    78 headlite, handle bars,
    1 set of ea-160/85mph guages,
    crash bars, cruise control
    Other 2 Wheelers
    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
  • wa407mpp
    • Jul 2007
    • 717
    Because of the design of the combustion chambers and the ignition advance system these bikes will burn just about any grade without a problem. In fact I could not tell a difference between regular and the better stuff.
    Fastmover
    lion". SHL
    78 XS1100e
    • mjpxs11sh
      • Jan 2011
      • 299
      • N/E, Illinois
      does anybody know whats supposed to be under the spring loaded clipped inside cover? mine's empty.
      Max
      Kerker 4/1
      Other 2 Wheelers
      • geobiker
        • Mar 2010
        • 82
        • Pa
        Leaded?
        I am a little more suprised that it says leaded gasoline, as the U.S. was switching over to unleaded by the early 80's, so you think that the placard would say unleaded (or both).
        I have read that there are diffent ratings for octane so I wouldn't worry too much that it says 90.
        I have run mine on 87 and 89 octane and not seen much of a difference. For the small cost difference, I run 89 octane for "peace-of-mind".
        1979 F
        Mac 4-2 Exhaust
        T-Kat Fork Brace
        Spade Fuse Box Mod
        Stainless Steel Braided Brake Lines
        140.0 Main Jets
        45.0 Pilot Jets
        266 X-2 Needle Jets
          The octane numbers back then were different then they are now. Regular is still basically the same now really as far as anti knock as it was back then, but they use a different formula that comes up with different numbers. If you look on the pumps, the octane shown on the pumps is a combination of research octane and pump octane, that sticker is based on research octane which is higher, pump octane is lower and they average the two for the number shown on the pump.
          • geobiker
            • Mar 2010
            • 82
            • Pa
            Clip
            I use the clip to hold my insurance card and registration card . . . I don't know if that is what it was designed for!?
            1979 F
            Mac 4-2 Exhaust
            T-Kat Fork Brace
            Spade Fuse Box Mod
            140.0 Main Jets
            45.0 Pilot Jets
            266 X-2 Needle Jets
            • XJkid
              • Jun 2003
              • 280
              • Elk Grove, Ca.
              What about leaded vs. unleaded? Should I be putting in a "lead substitute" to protect my valves?
                • 8863
                Pretty sure it was for the special cable used to compress the shocks for changing the rear tire. Then you could remove the axle without it interfering with the exhaust. It works great for document storage and a few Xtra bucks for emergency gas.
                • Rasputin
                  • 3192
                  • Lacombe, Alberta, Canada
                  That would be good in theory but my 79SF and others also have it which did not require the use of the cable. Myself I use it for document storage. I use a resealable bag as well so no unwanted water gets to them though.
                  2-79 XS1100 SF
                  2-78 XS1100 E Best bike Ever
                  • mjpxs11sh
                    • Jan 2011
                    • 299
                    • N/E, Illinois
                    i would have thought the compartment was there for something.
                    the fuel i guess doesnt matter, we're stuck with ethanol that doesnt burn as well, but like i noted, my bike doesnt seem to care what it runs on, it just runs. i dont remember the manual specifying anything in the compartment. ins card and registration sounds like a good use. thanks all
                    Max
                    Kerker 4/1
                    Other 2 Wheelers
                    • ViperRon
                      • Feb 2011
                      • 1062
                      • Woodstock, VA
                      original owner
                      When I got my bike !980 G the cable for tire change was in the compartment and that is where I keep it. The wrench for use putting the cable on was in the tool pouch and as tight as the pouch is it would have never fit in there.
                      Rodan
                      1980 G Silverbird
                      1198 Overbore kit
                      Grizzly 660 ACCT
                      Barnett Clutch Springs
                      R1 Clutch Fiber Plates
                      122.5 Main Jets
                      ACCT Mod
                      Mac 4-2 Flare Tips
                      Antivibe Bar ends
                      Rear trunk add-on
                        My '78 came with the tire cable in the tool pouch with the rest of the tools; it's a very tight squeeze, but it does fit....
                        • ViperRon
                          • Feb 2011
                          • 1062
                          • Woodstock, VA
                          better man
                          Steve you are a better man than me I just can't get it in I have tried .
                          Rodan
                          1980 G Silverbird
                          1198 Overbore kit
                          Grizzly 660 ACCT
                          122.5 Main Jets
                          ACCT Mod
                          Mac 4-2 Flare Tips
                          Antivibe Bar ends
                          Rear trunk add-on
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            I've ALWAYS ran super in ALL my bikes... I like to error on the side furthest away from detonation....
                            As for lead substitute they really don't make anything that actually really "substitutes" leaded gas, unless you wanna run leaded race fuel. A little marvels Mystery Oil or such in the tank every now and then will help buffer the valve to head impact. I squirt a little Lucas Fuel System treatment in the tank of the XS every other tank. I buy it by the quart for my diesel. Its got a chemical in in that works as an upper cylinder lube. I like to pretend its lubing my valves I don't know that it actually is I just like to hope
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                            2005 V-Star 1100 Classic
                              • 8051
                              That decal says "RESEARCH" octane. That is the least severe method to rate gasoline. The most severe rating is "MOTOR" octane. If you look at the pump, you may find "R+M/2". 87 at R+M/2 is probably at or more than 91 RESEARCH octane.
