hey all. i just happened to come across the side cover sticker on my 81SH, and it says "Regular (Leaded ) 91 Octane Min". ive been using Reg unleaded 87 Octane without any issues except probably mpg, but havent ckd as of yet.
fuel octane
fuel octane
Max
81 XS1100SH Black Beast Mutt
Kerker 4/1
stock carbs and air box.
78 headlite, handle bars,
1 set of ea-160/85mph guages,
crash bars, cruise control
Other 2 Wheelers
78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
94 CBR1000F jet kit,Two Bros pipe, K&N FilterTags: None
Because of the design of the combustion chambers and the ignition advance system these bikes will burn just about any grade without a problem. In fact I could not tell a difference between regular and the better stuff.Fastmover
lion". SHL
78 XS1100e
does anybody know whats supposed to be under the spring loaded clipped inside cover? mine's empty.Max
Kerker 4/1
Other 2 Wheelers
Leaded?
I am a little more suprised that it says leaded gasoline, as the U.S. was switching over to unleaded by the early 80's, so you think that the placard would say unleaded (or both).
I have read that there are diffent ratings for octane so I wouldn't worry too much that it says 90.
I have run mine on 87 and 89 octane and not seen much of a difference. For the small cost difference, I run 89 octane for "peace-of-mind".1979 F
Mac 4-2 Exhaust
T-Kat Fork Brace
Spade Fuse Box Mod
Stainless Steel Braided Brake Lines
140.0 Main Jets
45.0 Pilot Jets
266 X-2 Needle Jets
The octane numbers back then were different then they are now. Regular is still basically the same now really as far as anti knock as it was back then, but they use a different formula that comes up with different numbers. If you look on the pumps, the octane shown on the pumps is a combination of research octane and pump octane, that sticker is based on research octane which is higher, pump octane is lower and they average the two for the number shown on the pump.Cy
Clip
I use the clip to hold my insurance card and registration card . . . I don't know if that is what it was designed for!?1979 F
Mac 4-2 Exhaust
T-Kat Fork Brace
Spade Fuse Box Mod
140.0 Main Jets
45.0 Pilot Jets
266 X-2 Needle Jets
What about leaded vs. unleaded? Should I be putting in a "lead substitute" to protect my valves?"Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.
Originally posted by mjpxs11sh View Postdoes anybody know whats supposed to be under the spring loaded clipped inside cover? mine's empty.2H7 (79) owned since '89
Originally posted by bikerphil View PostPretty sure it was for the special cable used to compress the shocks for changing the rear tire. Then you could remove the axle without it interfering with the exhaust. It works great for document storage and a few Xtra bucks for emergency gas.2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
i would have thought the compartment was there for something.
the fuel i guess doesnt matter, we're stuck with ethanol that doesnt burn as well, but like i noted, my bike doesnt seem to care what it runs on, it just runs. i dont remember the manual specifying anything in the compartment. ins card and registration sounds like a good use. thanks allMax
Kerker 4/1
Other 2 Wheelers
original owner
When I got my bike !980 G the cable for tire change was in the compartment and that is where I keep it. The wrench for use putting the cable on was in the tool pouch and as tight as the pouch is it would have never fit in there.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
My '78 came with the tire cable in the tool pouch with the rest of the tools; it's a very tight squeeze, but it does fit....Fast, Cheap, Reliable... Pick any two
better man
Steve you are a better man than me I just can't get it in I have tried .To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
I've ALWAYS ran super in ALL my bikes... I like to error on the side furthest away from detonation....
As for lead substitute they really don't make anything that actually really "substitutes" leaded gas, unless you wanna run leaded race fuel. A little marvels Mystery Oil or such in the tank every now and then will help buffer the valve to head impact. I squirt a little Lucas Fuel System treatment in the tank of the XS every other tank. I buy it by the quart for my diesel. Its got a chemical in in that works as an upper cylinder lube. I like to pretend its lubing my valves I don't know that it actually is I just like to hopeDon
old:
1989 kawi ex500
1996 yzf-r6
1999 yzf-r1
2001 kawi zx-6r
2000 Ducati 748
2002 YZF-R1
2005 V-Star 1100 Classic
Originally posted by mjpxs11sh View Posthey all. i just happened to come across the side cover sticker on my 81SH, and it says "Regular (Leaded ) 91 Octane Min". ive been using Reg unleaded 87 Octane without any issues except probably mpg, but havent ckd as of yet.
