78 XS1100 Restoration
  • Jfries
    • Feb 2012
    • 110
    • South Bend , In.
    #61
    half way in
    well i tried n tried couldn't get the motor mounts to budge.. even with a little help from a ac pump on loan and air ratchet.. the frame and swing arm don't look that bad. the frame looks like its been powder coated all ready the rust that's on it is just wiping away and back down to the black coat with a light scrub and CLR. so im just gonna clean the engine/trans/frame the best i can while mounted. Then i can start getting her back together piece by piece as the money flows in. next month i get a new rear master cylinder one way or another then i just need to rebuild the calipers and get SS lines. I will get a carb kit probably in May, then it will be onto the regular maintenance stuff. I.E changing fluids/seals getting a new battery.. so she may get her first start near the end of May, Beginning of June. then it will be getting new tires and working out all the kinks/quirks. so i will update when things change/get done.
    1978 XS1100 Macho Maroon!
    http://i1248.photobucket.com/albums/...s/DSC00361.jpg
    • Shockman54
      • Feb 2012
      • 145
      • Minneapolis, MINN.
      #62
      carb cleaning/rebuild
      i used this guy on ebay to clean my carbs. he did a great job and there were no problems whatsoever
      1979 xs special, just finished the top end rebuild and then i still have lots of work.
      progress thus far...
      http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
      "If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
      • Jfries
        • Feb 2012
        • 110
        • South Bend , In.
        #63
        Halt what goes there?
        Its kreem coat!!! yes the marvelous cheap crap the PO decided to use in the tank without removing the sending unit OR THE PETCOCKS!!! sigh. and the screws holding the gas cap have all been stripped thank goodness they make vice grips ... but the tank.. i need to drill and rethread 3 of the 4 bolts on the sending unit.. thats why i have not been updating too much been busy!!!
          • 5062
          #64
          Yeah, I'm sure that didn't help.....
          If they look 'squished', they probably are; time to round up some good ones...
          I'll bet the PO tried to use compress air into the fuel line to open passages.
          • Jfries
            • Feb 2012
            • 110
            • South Bend , In.
            #65
            something liek that i know he told me when the carbs flooded with gas he blew air thru the fuel lins and it stopped flooding while it was running till the batt died then it flooded everywhere
            i just drained the oil lkast night and there was about 5 quarts in it but it was more gas then oil guess after it flooded he didnt change the oil just let it sit.
            so now i have that to deal with too.
            im about fed up
            • Jfries
              • Feb 2012
              • 110
              • South Bend , In.
              #66
              just wondering when i get the carbs cleaned and put back together is there anyone close enough that can come over( or i might be able to come to you if it runs enough) so sync and color tune the carbs. nor for me just i dont have the tools for that nore know how to do it.. im in South Bend, IN. and if anyone has the tools and willing to show me how to do it with them tools i would appreciate it.. its a long way off maybe a month or so i just wanted to get an idea of what kind of help there is out here.
              thanks, Josh
                im about fed up
                patience grasshopper..............those issues would exist with any 30+yr.old scoot thats been sitting for extended periods or PO'ed........
                • Jfries
                  • Feb 2012
                  • 110
                  • South Bend , In.
                  #68
                  update
                  Guess its about time for an Update.. been busy with other things but i got the bolts fixed on the tank. so im ready to clean that, i put the carb floats in hot water and 3 of the 4 instantly sank so i guess i know for sure now why it overflowed.. so getting the new floats is next on my list. other then that nothing else has been done to it. and im still in no hurry
                  • mikubuilder
                    • Jul 2011
                    • 548
                    • Westland, Mich.
                    #69
                    Hey Jfries, great buy, I just read up on your post...your bike is almost like mine, with few differences(mine is '79 and it set for almost 25 years)
                    But, a key is patience with those bikes... this forum is a great resource, unlike any other
                    the only thing that's slowing down my project is money, and I bet there are many members that have the same problem
                    Keep at it, and take a lot of pics, for us to google over them
                    Nick
                    1982 Virago 750 (it's alive!)
                    • Jfries
                      • Feb 2012
                      • 110
                      • South Bend , In.
                      #70
                      for sale
                      I put the bike up for sale as bills have come behind and toys must go.... i put up for 800 but will to take 650 as i need the money asap... text or call me at 801-712-6821, the bike is all together minus the carbs being on it seeing as it needs floats. ready for a new owner.. text anytime calls after 10am.. pm/email anytime. thx
                      • Jfries
                        • Feb 2012
                        • 110
                        • South Bend , In.
                        #71
                        Bike has been sold!
