78 XS1100 Restoration
  • Jfries
    • Feb 2012
    • 110
    • South Bend , In.
    yeah the carbs are already off i plan on doing a complete rebuild on them, as for the oil. i am gonna drain/flush everything. motor/drive/gears. and anything else i can...
    1978 XS1100 Macho Maroon!
    http://i1248.photobucket.com/albums/...s/DSC00361.jpg
    • Jfries
      • Feb 2012
      • 110
      • South Bend , In.
      TC's Fuse Box
      Is there a link to buy this, maybe on another site? i have been searching for a thread on it but i cant seem to spot it... or do i just pm for one?
        PM administrator TopCatGr58 (something like that) he sells them.
        ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
        • Jfries
          • Feb 2012
          • 110
          • South Bend , In.
          #34
          New turn
          After some talking with Crazy Steve. I decided not to just get her to run, but instead im gonna do a complete tear down and rebuild.. will take me a great awhile and any "Budget" inputs you guys have are greatly appreciated as i do not have real deep pockets. i will post pics of the progress as i can(which will be a lot since my wife has professional camera's!!) lol.
          • Jfries
            • Feb 2012
            • 110
            • South Bend , In.
            #35
            Got a little busy tonight?
            Last edited by crazy steve; 03-05-2012, 11:49 PM. Reason: Get post down to standard width screen...
              #36
              Great progres. They come apart pretty quick really. Its the cleaning and proper preparation before reinstalling that takes the real time. Enjoy and have fun!!
              • Jfries
                • Feb 2012
                • 110
                • South Bend , In.
                #37
                pulling the motor
                Ok i need to pull the the motor next.. can i pull it as it sits? i see a forum about laying the bike on its side i just dont know if i wanna do that i might not be able to get it back up if i cant do it. i know i need to pull the final drive off. is there any other way to do it buy urself without laying it down? or aybe someone close enough to south bend to come help me? thanks
                  #38
                  If you're doing this by yourself, the easiest way I've found is to strip the frame of everything except the centerstand (including all the motor mount bolts), then tip it forward until the front is on the ground. Pick up the rear and 'close' the centerstand, then lower the rear to the ground. Put some padding down and carefully lay the motor/frame over on it's left side. Lift the frame straight up, and there you are....
                  • Jfries
                    • Feb 2012
                    • 110
                    • South Bend , In.
                    #39
                    HA. i found a registration in the tool box.. this bike was last plated in 2001! lol
                      On the stand like you show it is fine. No need to pull final drive/swing-arm assembly. With the boot slipped back off the middle drive, remove the four flange bolts and the motor mount bolts. Engine comes out the RIGHT side, with the help of one other person. One other boby for help makes it easier to remove and install. Also, if you haven't already, remove the coils up on top-side of frame. otherwise the valve cover won't clear. Your choice, but this IS the easiest way for removal. Did it myself ONCE, but would advise another set of hands.
                      • Jfries
                        • Feb 2012
                        • 110
                        • South Bend , In.
                        #41
                        i did remove the coils.. i just ran to get some Pb because i was out and the motor mounts wouldn't turn and i didn't wanna force them. i don't have another set of hands besides the wife and she wont help lol.. i do have an old mattress then 6inches of foam so i might put it on its side like Steve said to do.im we shall see. i may just have to tear down what i can and leave it on the mounts i don't know yet. but plenty of time to figure it out...
                        • Jfries
                          • Feb 2012
                          • 110
                          • South Bend , In.
                          #42
                          good deal
                          http://www.ebay.com/itm/4-YAMAHA-197...sories&vxp=mtr is this worth it seems kinda cheap so i wanted to ask?
                          • Jfries
                            • Feb 2012
                            • 110
                            • South Bend , In.
                            #43
                            even cheaper?
                            http://www.ebay.com/itm/Yamaha-XS110...sories&vxp=mtr this is is even cheaper for all for kits for 50$
                              #44
                              Not sure about the CarbCapital ones, never used that seller. Georgefix is a great seller to deal with. He knows our bikes and carbs and knows what you need. I have bought a lot of things from him and always been very happy with the purchase.
                              • Jfries
                                • Feb 2012
                                • 110
                                • South Bend , In.
                                #45
                                Nooo
                                Stupid Snow as halted my progress for now!
