New Forum! Tools!
    New Forum! Tools!
    In our continuing effort to improve this site, we've started a new forum for 'Tools'. Up 'til now, they've been put various places but we thought having them in one place might be helpful. This is the place for those 'must-have' specialty tools, both store-bought and especially the home-made ones. Got one you built that works? Saw one that you thought was pretty cool? Posted one sometime in the past? Here's the place to post a link to it so you won't have to go searching for it!
  • Irukandji
    • Apr 2011
    • 75
    Hand made tools
    • Aches n Pains
      • 349
      • Reston, Va.
      Thanks
      As is repeated over and over on this forum, you guys are the best. I belong to a great many fishing, cycle, guitar, etc. forums and this is the most informative, easiest to use, and best run of the many I belong to.
      Thanks again, you're keeping an old man riding.
      Aches n Pains,
      Doug
      1995 KZ100P
      Pods, jets, pipes, cam adjuster, oil cooler
      1977 Ironhead - custom build
      Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
      Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
        carb float removing tool
        You just have to get a picture of Ken Talbot's carb float pin removing tool. It is so simple, yet ingenious!
          I'm ashamed to say I couldn't find it.... got a link?
            Do a search using "ken talbot pin"
            1/23/09 was the date of the posting with the pic. I believe the subject of the posts started with "stuck float pin"
              • 8061
                The one Ken made that I used is pictured in post #74 HERE. Could not find the dimensioned layout of it.
                I had a set wiht all four pins stuck as they could be. I was certain I would snap off a post or four. Used that tool and all four came out with nothing broke.
                  Thanks guys! I looked for that post (even used the right key words, I swear) for 45 minutes one day, but the search engine must have been having an obstinate day! I'll try to get something put together....
                  • mack
                    • 2411
                    • Ontario, Canada
                    Ken sent me
                    one of his tools and as others have stated it's great. I had one stuck so bad that it bent the tool. I wound up cutting the float out with a dremel. I just pounded Kens tool flat again and it has removed probably 20 or so more with no problems at all. If you can't find the link Steve, I'll take some measurements tommorrow and PM them to you so you can do your magic.
                    mack
                    79 XS 1100 SF Special
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    https://youtu.be/wB5Jfbp6SUc
                    https://youtu.be/RaI3WYHSuWA
                    Frankford, Ont, Canada
                    613-398-6186
                    • Irukandji
                      • Apr 2011
                      • 75
                      Measurements for Pin removal tool
                      • Irukandji
                        • Apr 2011
                        • 75
                        needle tip removal tool
                        Credit to Tropic-al
                        Originally posted by Tropic-al
                        Fireplug, don't feel bad. There's a bunch of real good mechanics and shade tree ones too, that have been in this predicament. While doing my carbs I managed to break 3 out of the 4 tips in the carb throat. After trying all the options adviced to by the friends at this forum I could not get them out.
                        Finally, I gave up and called my friend who I knew would figure out a way.
                        Sure enough, here's what he came up with.
                        He found small drill bits the same measurement as the hole where the needle was in. I believe around .024in. He cut a bolt to size and drilled a hole in the head to fit the bit in, rounded the hex out of the bolt somewhat and matched an acorn nut to fit.
                        He cut 2 sizes in lenght of the bits and started with the short one to press it out. When it topped out he changed to the longer one and VOILA !!
                        • WMarshy
                          • Apr 2009
                          • 2402
                          • Mexico NY
                          Hi guys,
                          I'm looking at buying a float level tool and could not believe they are selling for $30the on ebay. Do any of you have a preferred source to get a float level tool...possibly cheaper than $30? Maybe someone has built their own? Thanks!
                          '79 XS11 F
                          Stock except K&N
                          '79 XS11 SF
                          Stock, no title.
                          '84 Chevy K-10 "Big Blue"
                            • 8893
                            Nothing fancy needed to set the float levels, just a good eye.
                            http://www.harborfreight.com/6-inch-...ler-93684.html
                              • 8061
                              Do you mean this tool?
                              I have one, but I don't remember where I got it.
                              A quick search turns up $23 at Amazon.
                              Do you have a dial caliper?
