Re-birth of MadMax.. ---- 79 Yamaha XS1100
  • Madmax79
    • Feb 2012
    • 42
    • Dallas, tx
    Originally posted by trbig
    Man, I can't believe that you didn't like the backwards bicycle seat that Chop had on it?? lol..
    I hope you get more performance out of it than he did. Even with the chain drive, and lots of lost weight, (Plus his skinny azz weighing much less than me to begin with) it couldn't hang with my XJ riding around OKC. I think he was more into the fabbing than the tuning though. From the seat, back, it looks much better than when he had it, in my opinion.
    If you ever want a stock one somewhere in the price range you gave for that one.. keep me in mind, will ya? Good to see you found your way here to this board.
    ha haa LOL.. actually, when i got it, it already had a seat mod it differently. so it was actually pretty comfortable..
    and so far, the shop was able to fix all the gears and slowly putting the engine back together. and with the CR carb, it actually run like a champ!
    and with the new Tank and seat, I think I might drop another 50 lb.
    I think if the bike run as well as I'm thinking after I'm done with it, I might have add the big bore kit next winter to match the big carb it's running right now. it's gonna have a complete different look once I'm done with it.
    • Madmax79
      • Feb 2012
      • 42
      • Dallas, tx
      Naw.. I'm just talking straight line acceleration. Not a lot of twisties in OKC.. lol.
      Also wondering what he's doing exhaust-wise. Chop just had a single washer welded into the end of the exhaust for a tiny bit of backpressure.
      Also love the piston/rod looking master cylinder.
      when i got it, it just has 2 into 1 straight pipe running, I'm still not sure what I want to do to it until it's close to finish. I really love the open exhaust sound, but I'm thinking possibly run it all to one side like that inspire v-rod? either way, I need to make sure to tuck the exhaust in more, so when I lean into the corner, it will have more clearance.
      and Thanks, I thought a lot of peep might flame me for that little brake reservoir, but I'm super happy with it..
      • Madmax79
        • Feb 2012
        • 42
        • Dallas, tx
        Originally posted by Rooster
        That is an awesome looking bike I'm glad you posted it the vapor digital guage is what I've put on my 79 and I am looking forward to seeing more of your project.
        thanks rooster.. did you have all your other stuff functioning beside just the speedo and RPM? just trying to find out if all other function could be hook up to usable?
        • jimbyjimb
          • Feb 2010
          • 263
          • Seattle
          #34
          That is by far the coolest 1100 build I've ever seen. Awesome job.
          1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
          2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
          1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
          1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.
            • 2098
            X-Pipe Candidate ?
            This type of exhaust would give you good clearance and the performance no other exhaust can match.
            • Rooster
              • Oct 2009
              • 84
              • Lacombe, Alberta, Canada
              #36
              Vapor
              So yes they all work, but I had to buy the dash board to get indicators but it really is just as simple as finding the wire for each ie: signal, low fuel light, neutral, high beam and connecting to the location you want. I used the extra LED's they included in the kit except for the resistance sensitive low fuel light. The two lights on the top are like a soft warning for temperature, and an over rev warning they don't do much else.
              Even a blind monkey gets the odd banana.
              1979 XS 1100 special (been down the PO trail and it was messy)
              • Madmax79
                • Feb 2012
                • 42
                • Dallas, tx
                #37
                Thanks Jim
                • Madmax79
                  • Feb 2012
                  • 42
                  • Dallas, tx
                  #38
                  http://www.x-pipe.com/motorcycle.html
                  Hmmmm... I like the shape of it, but not sure if I like it 4 into 2? I wonder how that would sound? I actually like the way it's running straight pipe 2 into 1 set up, but just need to tuck it in more like the x-pipe..
                  • Madmax79
                    • Feb 2012
                    • 42
                    • Dallas, tx
                    #39
                    awesome!! I just want the mph, rpm, and mileage works, rest of it would be just bonus for me! I ran it for a while without any speedo, it didn't have one when I got it.
                    • Madmax79
                      • Feb 2012
                      • 42
                      • Dallas, tx
                      #40
                      Transmission is getting a overhaul. and slowly back together! Can't wait.
                      • GARTHXS
                        • Nov 2007
                        • 1631
                        • Seattle
                        #41
                        Very cool!!
                        91 kwaka kz1000p
                        Stock
                        ( Insert clever quote here )
                        • tweeleft
                          • May 2009
                          • 110
                          • Bend Oregon
                          #42
                          As Garth says Veeery Coool
                          Keep the shiny side up
                          1979 XS1100SF
                          Mac 4-1
                          Drilled airbox Uni filter
                          Vmax bars
                          Virago 1" shorter shocks
                          30K miles
                          http://i1228.photobucket.com/albums/...429_135845.jpg
                          1981XS1100SH
                          '80 G Forks and Triple Tree
                          '80 G tank
                          Mac Turnouts
                          Virago 1" shorter rear shocks
                          SH Headlight
                          http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                          61 Wife
                          83 Son
                          86 Son
                          89 Daughter
                            • 2098
                            Sample
                            Here it is on a CB750:
                            This is a good read if your'e interested in releasing the potential of any engine:
                            • Madmax79
                              • Feb 2012
                              • 42
                              • Dallas, tx
                              #44
                              http://www.x-pipe.com/ASC.html
                              not sure if I like the sound of it?? I actually like what I've already got better. But i might just have a local shop re-fab a new exhaust for it when it's time. but thanks for point that out.
                              • latexeses
                                • Jun 2008
                                • 1491
                                • California
                                #45
                                Are the dogs on those gears really back-cut?
                                Everything on hold...
