Bluetooth communicator
    Originally posted by Azoroth
    They don't allow voice dial. So you have to pull out the phone to dial.
    One thing to consider about that "feature" is the phone you are trying to attach to. Android does not allow you to initiate a call via bluetooth unless you use a 3rd party app that will activate voice command with a long-press of the answer button on the headset. WinMo phones have always allowed initiation of a voice call via bluetooth, as does BBerry. What I'm trying to say is that it may be a limitation of the phone, and not the headset.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Voice dial is part of the command set for bluetooth handsets, but some handsets don't support the full command set. Every android phone I've worked with supported voice dialing with every bluetooth headset I've used, but the how to was NOT listed in the phone documentation it was listed in the headset documentation.
        • 3193
        Yup I found that out a couple of days ago. I was so mad about the fact I could not voice dial out on my new droid that I was going to take it back. The nice lady there just showed me how to do it.
          Every online forum I've looked at confirms that true handsfree initiation of a call via a bluetooth headset is impossible with ALL Android phones, unless you happen to find an app that will activate the voice command feature (I have, BTW). True handsfree calling means that the phone can be in your backpack, and if you want to place a call, with the phone locked, you can long-press the answer button on the headset and you hear a prompt of some kind (a beep, or a voice prompt) welcoming a voice command. You can then say, "Call Jim at mobile" and the phone will repeat back saying, "Call Jim at mobile?", and you say "Yes" or "Correct". The phone then makes the call. A single button press unlocks the phone and initiates the call. So far, Android does not do this with the phone locked - you must manually unlock the lock screen before initiating the call.
          • Cuda 69
            • Jan 2012
            • 676
            • Greenwich N.Y.
            Just wanted to let you all know, I found a great deal on CLI-MAX riding gear. I just ordered a Cardo Scala Rider Q2 Pro Multi set yesterday for,,,,wait for it.......$199.00 that is the cheapest I've ever seen it advetized for.And free shipping. 2 headsets 500 meters.blue tooth with fm radio
            CLI-MAXRidinggear.com oe more thing,,,make sure this works with your GPS,I here these don't work with them all. and Cat you can get the wired mike for this,extra $.
            FOXS-XS11SG
            1980 XS11SG-sold
            1999 Vulcan classic-sold
            1982 XJ 650-sold
            • Cobia
              • Jul 2007
              • 1587
              • Palm Beach County, Fl
              Hey Cuda,
              That's a great deal and a great find considering they retail for about $325 at discount outlets. Good find.
              Only issue now is that all manufacturers are switching to the new Bluetooth 3.0 standard whereby range limitations are greatly expanded because each unit serves as a "bridge" to the next one in line. So, the range limitations are, theoretically, eliminated because the farthest unit uses the closest one to bridge it to the next farthest one.. and so forth. I assume they'll be backward compatible, although probably will not enjoy this feature unless their firmware is updateable to the new 3.0 software.
              1980G Standard, Restored
              Kerker 4 - 1
              850 Rear End Mod
              Automatic CCT
              1980GH Special, Restored
              '82 XJ1100 (Sold)
              • trdriver71
                • 360
                • Edmonton Alberta
                so you got rid of the old flip phone ehh!!!
                '79 XS11SF
                • cywelchjr
                  • 4450
                  • Sacramento, CA
                  I don't know about earlier phones, cause I didn't try with them, but with my DroidX with gingerbread with the phone locked pressing the handset with a long press for voice dial does do a voice dial. It does take a moment as voice dial initializes, but it does wake up, open the voice command app and respond to commands given via voice. When you hang up the phone is still locked however, so that doesn't give a way into the phone, it only allows the user of the bluetooth handset to use commands in the voice command set, but when finished the phone is still in the locked state as it was before the voice dial session was started. I was curious as I had not tested this recently as I don't very often voice dial in these situations, but figured I'd check.
                  • Azoroth
                    • May 2011
                    • 82
                    • Idaho Falls, ID
                    Yeah I have an Android phone. I am able to voice dial with my motorola headset. I wonder if the 3rd party app will change with this headset.
                    Which app did you find that you like?
                    1980 Yamaha XS1100SG
                    1984 Honda VF700F Interceptor
                    1967 Yamaha YL2C
                    • tweeleft
                      • May 2009
                      • 110
                      • Bend Oregon
                      I use mine just to listen to music. It's more background music. Won't answer phone when riding. Hard enough hearing music. Keep the shiny up, guys. Never tried voice dail on my android
                      Keep the shiny side up
                      1979 XS1100SF
                      Mac 4-1
                      Drilled airbox Uni filter
                      Vmax bars
                      Virago 1" shorter shocks
                      30K miles
                      http://i1228.photobucket.com/albums/...429_135845.jpg
                      1981XS1100SH
                      '80 G Forks and Triple Tree
                      '80 G tank
                      Mac Turnouts
                      Virago 1" shorter rear shocks
                      SH Headlight
                      http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                      61 Wife
                      83 Son
                      86 Son
                      89 Daughter
