Finally got the carbs done!
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    Finally got the carbs done, hope they work half as good as they look, even used allen screws for the choke lever
    81 XS1100H
    I like the color on the brackets! Maybe someday I will do that!
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      Thanks, I wanted some contrast, I hate to install them now, I just want to stare at them on a shelf
      81 XS1100H
      • mack
        • 2411
        • Ontario, Canada
        The outside
        certainly look very clean and shiney. How did you polish them?
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • old_skool
          • Nov 2011
          • 554
          • Ohio
          Aluminum paint.
          81 XS1100H
            • 2078
            Nice Job!!!They look great, hope they run as good as they look.
            • RJFort
              • Jan 2012
              • 92
              • Bristol, CT.
              paint
              did you have to use a special paint in order to make sure the gas and ethanol don't eat the paint away, since gas essentially is a solvent? I want to paint mine as soon as I get them clean and rebuilt.
              Rich (Ringo)
              '79 XS11 Special
              '02 VTX1800C (I know not a Yama but still mine)
              • old_skool
                • Nov 2011
                • 554
                • Ohio
                Nope, just used a standard metallic aluminum paint, there are some clear coats that offer some moderate fuel resistance, but I didn't want that much buildup on the carbs, I know gas can inadvertently get on these from time to time if you're constantly removing them, or have a bad petcock, leaking tank or pulling fuel lines, but for the most part, the external parts of the carb should not be getting doused with fuel, and if they do, I'll just touch them up. Out of all the bikes I've owned, I've never encountered one with so many fuel issues as these models, almost as notorious as their tranny problems. My petcocks are currently fine, tank in good shape, hopefully when I fuel I'll be mindfull not to overfill, and for the most part prevent most mishaps and deal with the ones I have.
                I've read another thread before where several members have painted their carbs with great success without all the extra worry, and touch them up as needed.
                81 XS1100H
                  You know, I personally don't understand all the problems with leaking carbs. Ok, so I do. But it's not something I've ever experienced on my XS11, my carbs have NEVER leaked on my watch, my tank dripped some after I got it, and that tank is sitting on my non-titled frame cause it's almost more holes than not holes, so it got replaced.
                    • 7862
                    I think that's only because the bikes are 30 something years old and many have suffered neglect or improper maintenance at some point. I think once it's right, it's right. Just don't allow it to suffer neglect again. Enthanol free fuel would help, too!
