Washers
  • mack
    • 2411
    • Ontario, Canada
    Washers
    Anyone got a parts source for the washers that fit above the seals in the fork lowers?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 8634
    They come with the LeakProof seal kit, also comes with the snap rings. I've made my own washers before by grinding down a slightly larger washer.
    • mack
      • 2411
      • Ontario, Canada
      educate me Phil
      Leak proof seal kits?
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        • 8634
        They are a brand of fork seal. The picture doesn't show the snap rings, pretty sure it comes with them. If you call DK they can probably tell you for sure, they are helpful.
        https://www.denniskirk.com/leak-proo....prd/14151.sku
        • Rasputin
          • 3180
          • Lacombe, Alberta, Canada
          I am pretty sure that I have a set here. I am not sure if they are out of a standard or a special or if it matters. If the leak proofs have them then you may be better getting them from there but the 2 I have are in good shape.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
            • 9980
            Standard seals won't fit a special. They are slightly larger.
            • Rasputin
              • 3180
              Will the washers still fit Greg.
              2-79 XS1100 SF
                • 9980
                Not sure, I never tried. The standard seals are just slightly larger OD but I think the washers have a little leway.
                • Rasputin
                  • 3180
                  If anyone has measurements I can check these to see if they would fit. Need to head in the house as the wife is bitchin but I do have a set. Just not sure which they are.
                  2-79 XS1100 SF
                    • 8634
                    The Special's washers should be about 47.5MM, the seal OD is 48MM. Standard washers will probably not work, the seal OD on those is 49MM.
                    • mack
                      • 2411
                      • Ontario, Canada
                      I'll go with
                      the leek proofs, as they come with the washers. Snap rings are still available. Now all I have to do is save my lowers. Man the water problems with this bike were everywhere. Everything I looked into had rust. I'm not sure how I'm going to perform this but I have two dremel kits so I'm sure there is an attachement here that will clean out the slots good enough to see how bad they're pitted. I'm hoping the slot for the seal remained intact. tThanx for the directions. I'll get back in a couple days and let you know how I made out. (TOMORROW IS VALENTINES DAY, can't go out to the shop)
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
