Anyone got a parts source for the washers that fit above the seals in the fork lowers?
Washers
Washers
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
They come with the LeakProof seal kit, also comes with the snap rings. I've made my own washers before by grinding down a slightly larger washer.2H7 (79) owned since '89
educate me Phil
Leak proof seal kits?mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
They are a brand of fork seal. The picture doesn't show the snap rings, pretty sure it comes with them. If you call DK they can probably tell you for sure, they are helpful.
https://www.denniskirk.com/leak-proo....prd/14151.skuLast edited by bikerphil; 02-13-2012, 05:11 PM.2H7 (79) owned since '89
☮Comment
I am pretty sure that I have a set here. I am not sure if they are out of a standard or a special or if it matters. If the leak proofs have them then you may be better getting them from there but the 2 I have are in good shape.2-79 XS1100 SF
Couple of more parts bikes of which 2 more will live!Comment
Standard seals won't fit a special. They are slightly larger.Greg
Not sure, I never tried. The standard seals are just slightly larger OD but I think the washers have a little leway.Greg
If anyone has measurements I can check these to see if they would fit. Need to head in the house as the wife is bitchin but I do have a set. Just not sure which they are.2-79 XS1100 SF
The Special's washers should be about 47.5MM, the seal OD is 48MM. Standard washers will probably not work, the seal OD on those is 49MM.2H7 (79) owned since '89
☮Comment
I'll go with
the leek proofs, as they come with the washers. Snap rings are still available. Now all I have to do is save my lowers. Man the water problems with this bike were everywhere. Everything I looked into had rust. I'm not sure how I'm going to perform this but I have two dremel kits so I'm sure there is an attachement here that will clean out the slots good enough to see how bad they're pitted. I'm hoping the slot for the seal remained intact. tThanx for the directions. I'll get back in a couple days and let you know how I made out. (TOMORROW IS VALENTINES DAY, can't go out to the shop)mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
