soooo.... The LED's drove me crazy so I put the 1157's back in and went onto my next step of installing my 5 wire to 4 wire converter box. Love this Mod!
All my wiring for the trunk runs down the top of the fender under the seat so I took off the seat and double sided taped the box down to the upper fender under the seat and got to cutting and wiring. Got it all put together and now I have blinker/brake lights in the trunk. Went for a ride Saturday and a buddy following me said it was WAY better.
Just ordered load resistor's to wire into the mix to use the LED's... I figure I'm this far invested in the bulbs I may as well try to use them....
Obviously the load resistor is suppose to help my wont flash problem in turns... and my brake light bad bulb on light due to LED in brake light. I'm also hoping it will remove the flashback thru the LED blinkers caused by my single turn indicator light in the cluster. If not I guess we'll tackle that issue when we get that far.
BTW I WILL NOT post pictures of my 5 to 4 box for fear of the laughter.
I'm not an electrician...
I'm a butt connector & scotch lock kinda guy
Ya I had all the lights working (except feedback issue) before the box conversion. from our previous conversations I knew that the "trailer box" may make the LED's mad and it did. But I do like the Mod... The Resistors Superbrightled.com recommend are 6ohm 50w jobbies....
